Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 09-17-2010, 09:06 AM   #1
mooman
Senior Member
mooman's Avatar
Default U Joint press 04 Silverado
I have to change the U joints on my 04 Silverado.
They have the plastic retainers in them that i have to get out.
Does anybody know if the Harbor Freight u joint press would be ok for this one time use?
I'm also open to suggestions as to other ways I can get these out.
__________________
"I've got nothing against gay marriage as long as both the chicks are hot."
mooman is offline   Reply With Quote
Old 09-17-2010, 09:23 AM   #2
anodyne33
Senior Member
anodyne33's Avatar
Default Re: U Joint press 04 Silverado
I'm not familiar with the retainers you're speaking of, but I'd imagine that they'll have to come out before you get to the press, no?
I've done several u-joints and a few ball joints with my HF press and it's worked fine for me. To the point of blowing a cross through a cap without having a problem with the press itself.
anodyne33 is online now   Reply With Quote
Old 09-17-2010, 09:48 AM   #3
I can fix anything
Senior Member
I can fix anything's Avatar
You have to melt out the plastic with a cutting torch. Can't say about the hf press, but you can rent a press from autozone and get your money back when you are done.
I can fix anything is offline   Reply With Quote
Old 09-17-2010, 10:24 AM   #4
srmofo
Senior Member
srmofo's Avatar
Yup have to melt the plastic first. they practically fall out after that. However I rarely press my own u joints anymore. The local driveline/clutch shop only charges $5 and they have higher quality u joints than the crap that parts stores sell. It ends up being around $30 for a spicer joint installed. And they even pick up and deliver for free same day service.
srmofo is offline   Reply With Quote
Old 09-17-2010, 10:27 AM   #5
DavidB
Senior Member
I agree with srmofo. Call around and see if a shop will press them out for you. It'd probably cost less and be quicker.
DavidB is offline   Reply With Quote
Old 09-17-2010, 10:57 AM   #6
SpiderGearsMan
Senior Member
SpiderGearsMan's Avatar
front shaft ?
the rear one has clips
I have only had to do one ujoint on a post 99 c/k truck
huge improvement
__________________
SpiderGearsMan is offline   Reply With Quote
Old 09-17-2010, 11:02 AM   #7
mrholeshot
Senior Member
mrholeshot's Avatar
Just heat it up until the snake makes it way out. Just heat it up and youll know what I mean
__________________
Try to be the person your dog thinks you are.
mrholeshot is offline   Reply With Quote
Old 09-17-2010, 11:21 AM   #8
737mechanic
Senior Member
Not sure about the harbor freight U joint press but my wilton vise presses them out without heating anything up.
We would never heat them up at the shop I worked at because of the time it takes to get the torch and heat it up. There we all just took them to the hydraulic press and pressed them out.
737mechanic is offline   Reply With Quote
Old 09-17-2010, 11:29 AM   #9
mrholeshot
Senior Member
mrholeshot's Avatar
I can get them out faster using a torch. Just heat them up and give them a light tap and they are out. Takes about two minutes once you have the shaft in hand.
__________________
Old 09-17-2010, 11:48 AM   #10
I can fix anything
Senior Member
They can break that way. Melting them is the way to go.
Old 09-17-2010, 12:18 PM   #11
Freakazooid52
Quote:
Were I work another tech didnt remove the plastic insert and ruined a perfectly good driveshaft.
Propane torch works ok to if you have more time and no access to a OXY/ACT torch
Freakazooid52 is offline   Reply With Quote
Old 09-17-2010, 12:21 PM   #12
mooman
Senior Member
mooman's Avatar
I don't have acces to a OXT/ACT torch. So either MAPP or propane is the way for me.
I just don't want to damage the yoke heating them up.
Just called a drive shaft place by me and they quoted $135 for the two u joints and balancing of the drive shaft.
__________________
Old 09-17-2010, 12:26 PM   #13
I can fix anything
Senior Member
Yep when stuff aint done right things get broke.
Old 09-17-2010, 01:45 PM   #14
srmofo
Senior Member
srmofo's Avatar
Quote:
Thats about right including the balancing, which I will usually have done unless the customer is flat broke.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
