330Scott
Sorry about that, Chief.
These questions mainly have to do with using galvanized pipe or brass fittings after the filter on my compressor's piping.
Question #1: I plan on installing a "tee" between the regulator and the lubricator. Two legs of the tee will connect the regulator & lubricator, while the 3rd leg will be used to attach a quick connector. I picked up the needed parts today from a hardware store & while rereading some of the air compressor threads here I started wondering if the galvanized parts that I purchased should have been brass or some other material instead. My concern is because there will not be a filter immediately behind the quick connector will the eventual rust in the galvanized fittings cause a problem. And if so, can I avoid the problem by using brass fittings?
Question #2: What are you guys using for drain ***** in your compressor's piping. I looked at a couple today but neither one stated any specs or if they were applicable for air compressor usage. Or can I just get by with plugging in an open ended industrial plug into the quick connectors periodically to purge the water in the line?
Question C: Does anyone make a 1/2" to 1/4" brass reducer ******? If so, where can I purchase it? I have already searched Grainger.com's site & didn't see one. I could buy a 1/2" to 3/8" and then a 3/8" to 1/4" reducer ******, but would prefer to only buy one item if possible.
Thanks for your input, everyone.
Scott
Scott
