Generator runs but no power!
Lewisthepilgrim
seacoast NH
Hey guys hows it goin. I have a 6k constant run(7200max) Campbel Hausfield Generator. Its powered by a 11hp Brigs and stratton.
The generator starts up RIGHT away and runs perfectly. BUT there is no power being produced. I have pulled the cover off the generator and checked for power, 1.4v is the most power being produced from any of the wires.
Where should I start looking? I'm assuming it could be brushes? Is there another place I should start? Are there any good links to generator repair ?
Thanks guys!
box
Toms River NJ
i assume you checked the basic's like fuses and breakers?
The brushes dont go bad until many many hours of use, i how old is it?
GeorgiaHybrid
Extreme NW Georgia
Sounds like you blew the voltage regulator. Have you ever started the generator with something plugged in and turned on? if yes, you will need to replace it. The typical voltage is from 1.4 to 2.5 volts at teh plug when they are blown.
GeorgiaHybrid
Extreme NW Georgia
It should be a small circuit board on the end of the generator under the cover. Go buy a new one (they run about $50 to $75) and you should be able to see where it goes. You can also look at a parts breakdown of your generator to see where it goes.
What happens when you start a generator with a load attached, it will try to make 115 volts AC with the generator just barely turning over as you pull start or use the starter to crank it. It will blow trying to do that by over amping the regulator.
Always crank the generator, then apply the load. I try to do the same when stopping it, take off the load and shut it down.
GeorgiaHybrid
Extreme NW Georgia
It will have a regulator that is replaceable. I had to replace mine earlier this year after the tornado's hit due to the neighbor cranking mine while it was plugged in.
