Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 05-02-2012, 10:32 AM   #1
nippaero
Junior Member
Default New 45K Heater Install
I know some of these question have been beat to death but search is not turning up anything easy. I just installed my heater on the ceiling. I have not ran the gas line or vent yet. I'll probably do that sometime this fall before it gets cold. Can I run the fan on the unit to circulate air this summer without connecting everything up? What thermostat would let me turn on the fan?
nippaero is offline   Reply With Quote
Old 05-02-2012, 01:43 PM   #2
dave67fd
Senior Member
dave67fd's Avatar
Default Re: New 45K Heater Install
You can. Install any 24v thermostat that has a "fan" or "fan only" type switch/control. You will need to wire that additional line to the heater terminal "G".
You can use a programmable depending if it has that option. If so make sure you ground properly as shown on the wiring diagram. Also some programmables don't interact well with the Mr. Heater control so an isolation transformer maybe needed. Keep it simple and use a manual one.
There are a couple of thermostats designed for garage use and will allow you to go down to i believe 35 deg. but i don't think they have the fan only mode.
__________________
Check out my Build at:
http://www.garagejournal.com/forum/s...d.php?t=102939
dave67fd is offline   Reply With Quote
Old 05-02-2012, 07:44 PM   #3
nippaero
Junior Member
Great. Thanks. I am guessing as long as I only run it in fan only mode it won't matter if the gas is not hooked up.
Old 05-02-2012, 07:54 PM   #4
Mmfh
Senior Member
Mmfh's Avatar
When you finally hook up the stat of your choice, making sure it has a "fan only" position on the side of the stat, the red wire goes to "R", that's power, the "W" is white and that's for when the stat calls for heat, the "G" terminal and wire are for the "Fan Only" Setting.
You can hook up only the red and green wires if you only want to run the fan.
I did it to mine and its nice to have the air moving around without the heat.
__________________
Making the World a Better Place, One Engine at a Time!
Mmfh is offline   Reply With Quote
Old 05-02-2012, 08:26 PM   #5
D.PHILLIPS
Junior Member
what size is your garage? I am thinking of installing a 45,000 in my garage, it's 1200 sq ft. thanks
D.PHILLIPS is offline   Reply With Quote
Old 05-02-2012, 09:02 PM   #6
nippaero
Junior Member
It's 24x24. The ceiling is vaulted 9ft at the wall and around 14.5ft at the middle.
Thanks for the help guys. I haven't pulled my permit yet and still have to figure out the venting. Also need to run my gas line fromr the house. Will probably do it this fall.
Old 05-02-2012, 09:08 PM   #7
Mmfh
Senior Member
Mmfh's Avatar
Quote:
With that size of garage, I'd go with the bigger 75k if it were my money buying it. That way you don't have to wait forever for it to heat up.
Mm
__________________
Old 05-03-2012, 06:51 AM   #8
Friartuck
Senior Member
Friartuck's Avatar
D.Phillips,
I agree with Mmfh, for your 1200 Sq Ft area, you should consider a 75K unit or maybe even bump to a 100K unit. I installed a 45K Modine Hot Dawg for a 500 Sq Ft insulated but detached garage and it heats it OK, sort of struggles and wish I could have went the 60K unit instead. The larger unit will heat the area faster and the on time (cycle time) will be less thus saving $$$ per month
Friartuck is offline   Reply With Quote
Old 05-03-2012, 09:36 AM   #9
regguy1
Senior Member
regguy1's Avatar
You'll need a 75K unit for that size space.
I have a 45K in my 26' x 30' see it here:
http://www.garagejournal.com/forum/s...d.php?t=140674
__________________
Check out the inside of the garage:
http://www.youtube.com/watch?v=cZIhuocG2ig
regguy1 is offline   Reply With Quote
Old 05-03-2012, 08:00 PM   #10
D.PHILLIPS
Junior Member
Smile Re: New 45K Heater Install
Thanks for the imput, sounds like a 75,000 btu would be the way to go.
Old 05-03-2012, 08:41 PM   #11
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Are you in Florida or Canada? It matters!
Not to sound sarcastic here, but without knowing where you are located, what climate you are in, how tall the garage is, insulated or not, walls finished or not, ceiling finished or not, among other things, its real difficult to even begin to guess at what you might need.
Charles
Charles (in GA) is offline   Reply With Quote
Old 05-04-2012, 09:50 AM   #12
Highbeam
Senior Member
Quote:
You think? Even though the larger unit runs less it will be using more fuel per hour. Plus if you oversize your heater it can short cycle which will lower efficiency vs. a steady long burn. Seems that modern HVAC pros are sizing devices to run nearly constantly to maintain the set temp thus minimizing cycles and minimizing burner size.
Highbeam is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
