rvr6000
Long story short, the misses and I live in a 1 1/2 story home. Our bedroom encompasses the whole upper level (about 400sq ft). We're tired of the old window unit we put in every year (drug it in from the shed again today) to help keep it cool up there and have been talking about getting a mini-split ac system.
I would consider myself fairly mechanically inclined - Is this something I could tackle myself? I'm lucky in that where the indoor unit would be located is directly above where the compressor would be so no crazy line-set issues that I can foresee.
Speaking of the line-set, since it's gonna be visible from the outside, do these things just look like hell or is there a way to conceal them from view?
Power - If I understand what I have seen and read, the indoor unit gets it's power from the outside compressor? No need to run a special circuit or plug the inside unit into a wall outlet? Just have to run a circuit (240volt I assume) to the compressor.
Which model - always up for debate but what model/manufacturer do you guys recommend?
Thanks in advance for all your help.
