Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 06-16-2012, 02:26 PM   #1
Mikaman
Junior Member
Default Porcelain tile & engine hoist/engine stand
New house, new workshop floor, deciding whether to epoxy or do something else ... forgive me but you guys have GOT to be kidding about laying porcelain tile! I've laid a lot of tile, no problem doing the job, and I guess it would be OK just to park on, or maybe do the occasional oil change. But I can't imagine rolling a loaded engine hoist or engine stand over a grouted tile floor! Anybody here who really does that?
And dragging a floor jack from the corner of the shop to the car, must make a hell of a racket.
Maybe lay it with a really narrow grout line, like less than 1/8"? Or maybe would help if it was laid in a diagonal pattern (since I tend to move the hoist in straight lines parallel to the sidewall) so the casters might span the grout lines without getting stuck in a rut -- maybe/kinda.
I mean, other than that, the porcelain tile idea sounds good ... low cost, durable, attractive, no maintenance. But it seems to me that they'd be impractical for a serious working workshop. Or am I missing something, or overthinking it, or just plain wrong?
Mikaman is offline   Reply With Quote
Old 06-16-2012, 02:33 PM   #2
bdamico
Senior Member
Default Re: Porcelain tile & engine hoist/engine stand
Quote:
Yes. Read up. Look at the way Jack uses his shop and he has ceramic.
bdamico is online now   Reply With Quote
Old 06-16-2012, 03:52 PM   #3
Jack Olsen
Jack Olsen's Avatar
Yes. My ceramic tile isn't as strong as porcelain. I never thought about noise -- I certainly haven't noticed any difference from bare concrete. It isn't any more slippery, either. I've used jacks and jack stands on mine in ways that would make epoxy owners cringe. I've rolled a 550-lb engine over it perched on a small steel floor jack. I've spilled every automotive fluid there is on it. I've spilled paint stripper on it. Dropped tools. It's held up great. The only thing that doesn't wipe off clean with a paper towel is dried-on oil-based paint (and a razor blade takes that off).
Here's me hitting it with a 4-lb sledgehammer:
http://www.youtube.com/watch?v=elJtN6nRlhk
The key to tile strength lies in the way it's installed. If there are voids under the tile, you'll have problems. Like concrete, tile is very strong in compression, but weak in tension.
Jack Olsen is offline   Reply With Quote
Old 06-16-2012, 07:39 PM   #4
JakeKohl
Senior Member
JakeKohl's Avatar
Apparently, (I'm finding out in about 6 weeks) if you use a rectified tile, you can get a really tight grout line and avoid much of the "ka-chunk ka-chunk" when rolling things.
__________________
Jake Kohl
Greenville, SC
www.teamseacats.com
My Garage Journal Build Thread
"People complain about it being too expensive. People complain about it being too small. Nobody complains about it being too big."
JakeKohl is offline   Reply With Quote
Old 06-21-2012, 12:07 AM   #5
rickyrj1
Junior Member
I have had my porcelain floor for about 3yrs now with no issues. I have a kwick lift on it. It looks as good as the day it was completed. Black & gray 18" tiles with black grout.
rickyrj1 is offline   Reply With Quote
Old 06-22-2012, 09:19 AM   #6
slickgt1
Senior Member
Search my name, and "can your floor do this". You will see more action.
slickgt1 is offline   Reply With Quote
Old 06-22-2012, 05:09 PM   #7
Turbota
Turbota's Avatar
I am having glazed porcelain 20" x 20" rectified tiles layed on my 3-car garage floor (585 Sq. Ft.) as we speak. As someone mentioned, rectified tiles can be layed very close together with very narrow grout lines, if wanted.
For someone that may not know what a rectified tile is ... These are tiles that are fired as one very large piece. Then they are cut to size (after being fired) which results in a perfect size with perfect straight 90 degree edges. Because of this, they can be set very close together.
I don't know if ceramic tile is manufactured as rectified, but much of the porcelain tile is.
To get a cost idea of having my porcelain project done:
___________________________
Garage Floor Area:
30' W x 19.5' D
(585 Sq Ft.)
20" x 20" Tiles (Tilecrest 'Illusion'):
$ 20.55 per box of 6
37 boxes needed
$ 760
Thinset Dry Mortar (Mapei 'Ultraflex 1'):
$ 11.31 per 50 lb. bag
11 bags needed
$ 124
Sanded Grout (Keracolor):
$ 11.95 per 25 lb. bag
1 bag needed
$ 12
Delivery Charge:
$ 29
Tax:
$ 52
Installation Labor:
$ 1.50 per Sq. Ft.
585 Sq. Ft.
$ 878
Total Cost: $ 1,855.....($ 3.17 per Sq. Ft. Installed)
(Prices above includes a Lowes 10% Military Discount on Materials)
__________________
George Jones .. "I ain't ready for the junkyard yet 'Cause I still feel like a new Corvette"
Turbota is offline   Reply With Quote
Old 06-22-2012, 05:25 PM   #8
ScaldedDog
Senior Member
Default
Quote:
What gray tile? If I could find some, I'd do this.
Mark
Sent from my ADR6400L using Tapatalk 2
ScaldedDog is online now   Reply With Quote
Old 06-22-2012, 05:44 PM   #9
bdamico
Senior Member
Quote:
Yeah. I don't have much of a grout line in my garage. Why you going with sanded? Gonna do 1/8?
Old 06-22-2012, 06:03 PM   #10
Turbota
Turbota's Avatar
Yes, I told the tile guy I wanted 1/8" spacing between the tiles.
I was a little leary about finding a tile guy on Craig's List, but the guy that is installing my tiles is doing a great job, and the lines between the tiles are straight as an arrow. He is using a very long level too to make sure all the tiles are the same height.
The installer is originally from Poland, but has been here in the US now for the last 15 years laying tile ... He originally said on Craig's List that he charges $1.25 per Sq. Ft, but I told him that I would pay him $1.50 if I got a good job ... and he certainly is doing that.
I will post some photos of the completed job when my wife gets back from an out of the country trip on 4 July (she has the camera with her) .... my cell phone camera is screwed up.
All I have to show you is the outside of the garage ... which is really of no help.
__________________
Old 06-22-2012, 06:19 PM   #11
bdamico
Senior Member
Many of them--including big companies--advertise on craigslist here in miami. I wouldn't sweat it. The range seemed to be what you're paying and upwards of $2.50 for companies with employees. I think I paid close to a $1.50 with extras. And seeing how fast they laid the tile, I don't feel guilty at all because he did okay on an hourly basis. I'm really glad I did the baseboards. You should consider it if you're not already.
Old 06-22-2012, 06:37 PM   #12
Turbota
Turbota's Avatar
Tile baseboards would be nice, but on my house, the interior garage walls are some kind of a white painted cement stucco finish, so there is no drywall to get wet.
I am going to play this one by ear.
I might even consider that 5" rubber type baseboard, but I don't know how good it would stick to the painted textured cement walls?
My floor tile is kind of an 'earth tone' beige color. with some swirls in it ... if I could find that rubber baseboard in someing a little lighter than the common dark brown I have seen before, that might look good?
Jeeeze ... I wish I had a camera to show you of the tile job as it sets right now.
_____________________________
BTW .... For people that think tile garage floors will crack when you drive your car or heavy truck on it, that just ain't true. I have 16" x 16" ceramic tiles on both my driveway and my carport on my house in the Philippines ... and after driving on it for 2 years, there is not one crack! .... and ceramic is not as hard as porcelain.
__________________
Old 06-22-2012, 06:39 PM   #13
bdamico
Senior Member
You can pick that up from lowes or homedepot and see how it looks--return if it doesn't look good. My understanding is that the rolls adhere better than strips but my knowledge is limited. And if you do decide to do baseboards, don't offer/pay too much. It added $100 to my job and he made the baseboards from tiles cut lengthwise into threes. A ton of extra work
Old 06-22-2012, 06:52 PM   #14
Turbota
Turbota's Avatar
Thank's dbamico
I also am looking to get some of those oak finished cabinets that you put together and hang on the walls. I had them in the garage of the house I used to own in Illinois, and they were pretty well made and looked good too.
Right now, my house I just bought here in Cape Coral (photo above) is nothing but an empty 3-car garage (totally empty of everything) ... Hey, but really nice looking floors!
The tile guy said ... the garage floor tiles he is installing would even look nice inside the house!
And to be honest, I think I really like them a little better than the tile that are in fact inside the house ... maybe I might just move out in the garage when my wife gets back from her trip! ..... next is a nice flat screen TV out there
________________
EDIT ... And a small beer refrigerator!
__________________
Old 06-23-2012, 02:17 AM   #15
sheddownunder
Junior Member
A quick question - l can get a polished tile cheap, so is a polished porcelain tile ok for a garage floor?
sheddownunder is offline   Reply With Quote
Old 06-23-2012, 09:38 AM   #16
Dakota00
Senior Member
Dakota00's Avatar
You can use polished porcelain in your garage, you just have to be very careful when the floor is wet. It's very dangerous if you park your cars in the garage after it rains or snows.
__________________
Granite, Marble and Ceramic Tile Setter
Dakota00 is offline   Reply With Quote
Old 06-24-2012, 08:26 PM   #17
Carguy99
Senior Member
Quote:
this would be my question. I live in snow and rain country. I like the look but I wonder how slippery it would be???
__________________
One test is worth a thousand expert opinions.
Carguy99 is offline   Reply With Quote
Old 06-24-2012, 09:59 PM   #18
JakeKohl
Senior Member
JakeKohl's Avatar
Quote:
different tiles are...different depending on firing process, finish type, etc.... Best bet is to go to the retailer with a spray bottle of water and give them a try.
__________________
Jake Kohl
Greenville, SC
www.teamseacats.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
