bad_idea
I have the ram from an engine hoist sitting on a shelf begging for a project. I am thinking it would work great for a tubing bender, even better if I don't have to pump the handle on the ram 1000 times! I am thinking a fitting tapped into the cylinder should be all I need to make it function as a single acting cylinder. Should be able to operate it with the handle when the pump isn't hooked up.
I realize a pump, relief valve, control valve and hoses will also be needed. I am assuming a reservoir would also be needed.
I am envisioning building a portable pump unit that I can hook to different cylinders. Then tap quick connects into my bottle jacks, the ram, a hydraulic press, etc. This seems like a simple setup to me, almost too easy. What am I missing? Could I tap a quick connect into my floor jack and operate that with a pump?
To clarify, I want to use the ram as a hydraulic cylinder powered off of a pump w/ a control valve. I can foresee use of the hydraulic pump for other cylinders in the future and was thinking it would be more economical to have one pump setup and switch it from cylinder to cylinder.
Anyone have experience or knowledge on doing this?
