Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#5401 | |
Senior Member
Quote:
How about just loading the PDR in the back of Gus? Then when you get home use one of the lifts as a hoist (place chain or boards between and under the PDR)? ![]() However I do have to agree it would be good to have a set of forklift forks around... |
#5402 |
Senior Member
So what do you do when acronyms work on a couple different meanings?
When I think of PDR I think of Paintless Dent Removal for cars.
#5403 |
Senior Member
Chris, I vote for the Artillian Forks as well, but not necessarily just for the Portable Dirty Room, PDR extraction alone. Looking forward to Thomas's After Retirement Career (A.R.C.) as the Retirement Home Sidewalk Superintendent (R.H.S.S.), he will undoubtedly find the pallet forks indispensable as two of his new duties will be Chief Material Handler (C.M.H.) and Warehouse Storage Manager (W.S.M.). When you consider, as Thomas said, " And did I mention they come already powder coated John Deere green?", it is obviously not a frivolous expenditure, but an acquisition that is almost a preordained mandate!
One last thought for your consideration is that when Thomas has entered the A.R.C. phase of his life, he may not be up to the task of taking his ANVIL for those evening strolls; the JD equipped with those forks will allow him to take the ANVIL for many pleasant journeys about the acreage. It will also give you a break from his aimless wandering about the house and being generally underfoot!
#5404 |
Senior Member
The Artillian Forks seem like a good investment to me (I never ask about $ because it's a foregone conclusion that he'll be doing something anyway). I won't mind having him around more when he goes into A.R.C mode, but somehow I don't see that happening judging by how my retirement has been going these past three years. I'm busier than ever, but doing what I want to do (mostly).
Chris |
#5405 |
Senior Member
Miss Chris said: " I'm busier than ever, but doing what I want to do (mostly)."
I have to say: Congratulations! |
#5406 |
Senior Member
#5407 | |
Senior Member
Thanks for the McLarch Engine PORN... Some guys have all the luck!!
__________________
VISIT me at www.E-TekRestorations.com OR, read the blog: www.E-TekRestorations.blogspot.com Quote:
#5408 |
Junior Member
BB767, had to join the board and say what a great thread! Also, lived in Champaign for 5 years in college and spent many an evening at the Philo Tav
#5409 | |
Senior Member
Quote:
I have not put any shelves in the Stainless Steel Topped Benches, SSTB...............yet. I thought about it when I first built them but decided to wait and see what my needs were as shelves can be added at any point.![]() Since the bottom is 3/4" plywood and the back is 1/2" not to mention the 4X4 legs across the front, there is sufficient material to attach a shelf support structure of various designs. Those benches are deep enough that I would imagine you would only want a shelf that is half as deep as the bench is... ![]() ![]() ...as seen here on the Barn Bench, BB. Or alternatively put in a shelf that you could pull out on slides much as you would a drawer. The few items I'm storing under those SSTB presently (a porta power for one) are large and bulky and I need the large space. When you do build your benches be sure to post them on the Journal. Enjoy the reading you have before you. Thomas |
#5410 | |
Senior Member
Quote:
You'd need to be PDR, Pretty Darn Resourceful. Oh oh, more Chris test material!! ![]() Thomas |
#5411 | |
Senior Member
Quote:
![]() BTW Chris, I did order the Artillian Fork's today, I wouldn't want to disappoint my sweetie! Caring Thomas |
#5412 | |
Senior Member
Quote:
![]() Thomas |
#5413 |
Senior Member
It's been a long day but I wanted to get some of the construction details of the PDR posted.
![]() Grade 5 nuts for mounting the vise were TIG welded (Tungsten Inert Gas) to the back side of the steel plate. You can see where the top nut falls inside the outline of the leg... ![]() ...so that worked out pretty well. ![]() 1/4" steel plates were shaped to fit the bottom of the legs and then drilled and tapped for the caster mounting bolts. ![]() After the 1/4" plates were attached to the bottom of the legs they were shaped to fit the profile of the leg. ![]() These are the Blickle swivel casters selected for the PDR, attached with grade 8 bolts. Two of the casters will have positive stop-lock brakes. They are polyurethane so they won't flat spot like rubber ones would if they sit in one spot for a long period. Rated at 500 lbs (226 kg) each with sealed ball bearings to keep grit out. They have solid, machined aluminum alloy hubs and are beautiful, quality pieces that should make the PDR just glide across the shop floor and last for decades. Not too happy with the green color but that's the only way I could get polyurethane, so form follows function, just live with it. I bet once everything is powder coated you'll hardly see the green anyway..........at least that's the theory. ![]() ![]() With the caster plates attached to the legs, everything was laid out... ![]() ... in proper position. ![]() A shallow shelf that was made from large 1/4" angle was installed all along the bottom of the top plate and these small "L" brackets were fabricated to strengthen that angle... ![]() ... but more important they aid in holding the angle piece in correct and square position during welding. Note the small square in the middle to the right. ![]() To the front of that large angle a small 1" lip was attached... ![]() ![]() ...all around it to provide a lip to hang clamps on. I'll get some better pictures of it and post them later. ![]() There is more but it's late and I have a bed calling to me so check back for additional material. Thanks everyone. Thomas Last edited by BB767; 08-11-2012 at 11:42 AM. |
#5414 |
Senior Member
That PDR will be so awesome when it´s done at the powder coater, can't wait for the finished result!
#5415 |
Senior Member
I get the idea of welding the nuts on the bottom but I'm wondering why you didn't thread the table instead of just drilling through it.
#5416 | |
Senior Member
Quote:
Thomas |
#5417 | |
Senior Member
Quote:
Thomas |
#5418 | |
Senior Member
Quote:
#5419 | |
Senior Member
Quote:
Feel free to pass the thread on to others you feel might find it interesting/amusing or both. ![]() Thomas |
#5420 |
Senior Member
| Thread Tools | |
| Display Modes | |
