burleyfarm
My furnace room (forced air) consists of my 95% furnace and water heater, both propane. The furnace room is off my garage and is completely sealed with the exception of a makeup air vent leading from the outside. The room is about 6' by 3' and has a double door, completely sealing it off from the rest of the garage.
My problem is that I have major ice hanging from the roof in the general area of the furnace room both front and back of the garage roof. The furnace room is always very warm even when were gone for a week or two. I have 6 inches of fiberglass and another 12-15 inches of blown fiberglass over the room.
Any suggestions on how to get control over the build up of heat and ice?
I'm thinking of removing all the insulation and placing 2-3 inch rigid styrofoam between the rafters, sealing that with spray in foam for doors and windows and putting the original fiberglass back over the styrofoam. Does this make sense?
Would it cause a problem if I cut a vent hole in the top of one of the doors to let some heat out? My garage is heated so a little more heat coming into it would be great..
Thanks for your help..
