Racecarl
building an English Wheel
I am building an english wheel to make some new panels for the 51 Chevy in the background. The metal for the frame started out life as a shipping frame for a John Deere cornhead. The smaller tubing is 2 X 4 X .25 and the larger tubing is 4 X 5 X .25. The larger pipe for the upper roller is 2 7/8" oilfield pipe and the inner pipe is 2 3/8" oilfield pipe. The 'feet' are 1/2" bolts that can be adjusted to make the frame level and solid. All the welds were done with my Millermatic 251 using .035 wire and C-25 shielding gas.
I have an air bag from my work truck that I am considering using to press the upper roller down onto the lower anvil. I would use an air pressure regulator to adjust the squeeze pressure of the rollers.
The back side of the frame will be fitted as an air-powered planishing hammer. I am researching my options for the PH.
As far as the rollers go, I hope to be able to build my own or I might splurge and buy some. I have a few ideas to try first, but I want to finish the frame first.
Any comments or suggestions are welcome!
