it turns out i have .023 wire, i just checked tonight.
So i decided to take another stab at welding tonight and try some flat scrap pieces....I get everything set up, I ground the pieces down to bare metal and got my machine ready.....
Go to open the gas......ZERO pressure in the tank
I had the tank filled last summer and have not welded much the past year....
I always shut the tank off and purge the lines before calling it a day....Im gonna guess that my regulator may be leaking or there is a slight chance i had a brain fart and didnt close the tank last night....If there is a leak and it ran out during my welds last night it could explain the epic fail of welds i posted
Looks like im gonna need to have the tank filled and then check the connections with some soapy water to make sure its all tight...
