z28snksknr
So I just bought a house with a 2 car garage. The garage floor on one side has sunken a fair amount- there is a crack form the middle of the garage at the wall extending diagonally to the corner of the opposite wall (near the garage door). The triangle of concree this created has sunken about 8" at it's deepest and the deepest corner has been broken out so there is no concrete in that corner, just dirt (I was told a sewer pipe broke and washed out under the slab)
The end result I am looking for is an epoxy floor coating and possibly a 4 post lift (years down the road).
I want to try and jack the cracked and sunken part with a few car hydraulic jacks (2 2-1/2ton) and try to backfill under the slab, then lower it. Do you think it would work? What should I use to backfill under it?
Thanks in advance for suggestions.
