Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 07-31-2009, 10:37 PM   #1
steve h
Junior Member
Default house blower fan
I s there anyway to speed up the blower motor for more air flow through my ducs,i was told that you rewire for more speed?thanks for any help,steve
steve h is offline   Reply With Quote
Old 07-31-2009, 10:51 PM   #2
Offshore
Junior Member
Default Re: house blower fan
Most blower motors I see have a receptacle fitting where a plug is moved to the desired speed. Usually mounted on the motor. Mine came from Grainger and has 5 speeds.
Offshore is offline   Reply With Quote
Old 08-01-2009, 06:03 AM   #3
lilredex
Senior Member
Quote:
Depends......is it a belt drive or direct drive fan?
lilredex is offline   Reply With Quote
Old 08-01-2009, 10:43 AM   #4
IDASHO
Senior Member
If it is a belt drive, find a smaller pulley for the motor, and a shorter belt.
__________________
See my garage build here:
http://www.bonnefinstudios.com/kwb/paradise/garage/
IDASHO is offline   Reply With Quote
Old 08-01-2009, 10:46 AM   #5
fatboy99
Senior Member
That should be a larger pulley for the motor and a longer belt
also look to see if the motor pulley is adjustable loosen the set screw and move in and shorten the adjuster bolt on the motor
Brad
fatboy99 is offline   Reply With Quote
Old 08-01-2009, 01:42 PM   #6
lilredex
Senior Member
Quote:
Brad
Exactly, but be aware that if you have a 1/4 HP motor on there it is real easy to overload it, especially if it runs continuously or has long cycles. After the motor runs for 15/20 min. or so and you cannot hold your hand on it comfortably you are working it too hard.
You can reduce the fan pulley size also.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
