westernmdlawn
- Joined
- Oct 15, 2009
- Messages
- 5
Hello,
I am going to be starting to construct my new garage project in the next week or two. I am wanting to heat this space with a wood burning stove as a primary heat source and have an auxillary source as well.
My Questions:
1.) What is a good auxillary heat source which would be convenient and cheap to install. Not really concerned too much about cost to operate it as it would not be used often.
2.) How do I decide what size wood stove to purchase? I don't want a stove that will over heat the space constantly.
Garage Specs:
Dims - 24x32x10
Framing - Post Framed
Insulation - I plan to use batten insulation and an OSB covering inside. I plan to use 6x6 poles and install the girts between the poles (2x6's) like book shelving. This will allow me to use std batten insulation. I'm not sure how best to insulate the ceiling - any suggestions would be appreciated.
Floor - 5" concrete slab
Openings - 3 std (3'x3') insulated windows, 1 std steel entry door (36"), 2 (9x9 OH garage doors - insulated)
Exterior will be steel
Thanks in advance!
My Questions:
Garage Specs:
Dims - 24x32x10
Thanks in advance!
