2 car garage almost finished...
pixelmonkey
oklahoma
It's Not yet complete. ;)
Few issues with the house that need to be fixed before I do much more to the garage, but for the main construction, it's finished. Some more painting and cabinet door adjustments and I will be happy.
the next version will be built better... might start that in spring. *looking at a new house with larger yard and larger garage*
CONSTRUCTION NOTES:
- frame is 2x4 pine lumber
- sides and face plates are 1/2" plywood
- shelves are 5/8" particle board for top shelves and 3/4" for lower shelves
- paint is oil based enamel from lowes.
- shelving rubber is from lowes. *label shows it to be used under a tread mill. i think it was a 4'x8' roll for $40
- legs are brushed aluminum, adjustable. online search should help.
- the "closet" cabinet next to the garage clears by 1/2"
- entire cabinet system is screwed to the wall and doesnt require legs or floor support, but I added them for safety to the lower cabinets.
- "closet" will support me at 250lbs
- counter top is 3/4" plywood. 4'x8' sheet was cut into 2'x8' and glued together and screwed from each side using 1 1/8" sheet rock screws
- metal secured to counter top
- metal with counter top screwed to frame
the overhang near the tool boxes will be used for a vice. holes will be drilled through the metal and wood to hold it in place.
MORE PAINT will be added. white on edges and backs of doors not yet painted. then a few more additions to the doors will come over winter.
more to come!
chris<pixelmonkey>:D
P
pixelmonkey
oklahoma
I like the work bench is it stainless?
Thanx Trevor
negative... .063 aluminum
price for the 4'x10' sheet was $212
90 degree break was $15 *for the wall.
the roll in front was via 2x4 and a few hours of work.
price for stainless was almost double the price.
i figured since my plan was to only be in the house for 3 years, the aluminum would work for my needs.
next version will be stainless
txturf4u
I went with Aluminum also was under 100 an 4X10 sheet from Reliant Steel. Stainless was just too much. Like the cabinets also looking good.
1AB JAG
Beervana aka Portland, OR
Looks great!
I love to see all the pictures of garages on this site. Hopefully I'll take all this inspiration and get my garage finished this spring. It's been a work in progress for way too long!
I've been wanting to use Sketchup for a while now too. How helpful was for you?
P
pixelmonkey
oklahoma
sketchup was a huge help in sizing and material needs.
if you're going to build anything custom, it's a great help!
use the measurement tool, change the field of view and use the standard views *left, right, top bottom* to print some decent scaled drawings.
hope it helps!
viper522
SE FL
chris that sketchup file will be a big help. i have almost the same exact layout. only change I need to make is the workbench has to fold up or down to allow both vehicles to park inside should a hurricane come through.
P
pixelmonkey
oklahoma
with the help of a space heater, i started painting!
MORE PHOTOS HERE
P
pixelmonkey
oklahoma
glad it helped! i have enough room in the garage for 1 bike, a chevy s-10 and a subaru forester.
Cool art. Nice DRZ
thanks! the DRZ left me last week. wasnt riding it enough, so have a few toys to replace it ;)
Like the art and the benchtop.
Great job.
if i had to do it again, i would pay to have the metal rolled at a metal shop and the breaks exact. was quite a bit of work to get it laying down correctly.
the art was something of an after thought. I first had plans to add something like a troy lee mural or just a few decals from motorcycle products. i thought i should do something a bit more original, so i made a few parts inside sketchup, viewed them with a wide angle "depth of perception" and turned them to fit where i wanted. I think it makes the layout a bit more universal, so when it's time to sell the house I shouldnt have a need to remove stickers or paint over the layout.
