VWandDodge
- Joined
- May 20, 2011
- Messages
- 951
I have a H/F parts washer my father bought me in the early 1990's. Naturally, it is a kwality item hence my need to modify it slightly. If/when I clean heavily greased or gunked material the simple filter tends to clog thereby affecting the performance of the pump. What I want to do is install a bung at the bottom of the tank and plumb for ½" pipe to a two stage filtration setup before routing the fluid back into the tank. I'm trying to source either a cartridge filter setup or something similar where the housing is transparent. Any suggestions are greatly appreciated.
