What's your workbench look like?
dittle fart around
Vancouver, Washington, USA
Here's my new workbench. The beautiful Vana White is showing the fine craftsmanship of this 30 x 72 all steel workbench. Actually that's my wife Donna playing the spokes model part, and doing a wonderful job, I must say.
Made of recycled soccer goal posts, my only expenses were the casters and a sheet of 1 1/8" plywood. All told it cost me 70 bucks and 18 hours labor. The steel came with a combination of rust and white paint and that took many hours to remove.
The new workbench takes the place of one I built when I was 19. That one started out as a stained glass workbench with an integrated light box (for seeing the pattern through dark colored glass). It had been moved many times and over 700 miles to it's current location. I modified it in 1991 to work as a mitre saw extension and general catch all in my garage. It was kinda sad to see the old bench go after 35 years of projects.
The idea behind the casters is so the new bench can be moved to accommodate the work. Roll it out onto the driveway, and I can use it as a extension for my table saw and save time sweeping the garage. Always a plus.
jimbob1
Nice. I love steel framed work tables. That would be a great welding table frame.
milner351
Nice work - anymore - I put casters on everything because the more stuff I have on casters the more I like working in my garage - as there's always a reason to make room here or there to get a project done.
Killer95Stang
great looking bench.... where do I find some of crappy rusty, painted goal post steel? It looks better than the new stuff I pay top dollar for..
Jim Stabe
San Diego, Ca
3/4" steel top for fabricating. Receiver tubing in the corners for mounting tools (planishing hammer, shrinkers, beverly shear, vise, etc). It weight about 600 lbs
daveroy
Omaha NE
Mine looks something like this:
(not usually that messy... I swear it's not!)
The bottom two drawers are not really drawers but 'boxes' on three skate trucks each (probably older than I am... have steel wheels!)
Jeff
Sonova Beach
Two workbenches along the back wall and a work/assembly table in the middle.
W650Mike
North Central Texas
Right after a fresh pegboard and paint + re-sealed the bench top while it was cleared. ...It got a little cluttered since that photo...you know how it is.:)
frankkl
Mine is 10' long. Half is steel, half is mdf. I will probably change the top for a full sheet of 3/16 steel.
Jackfre
N CA
That is nice work. I too use casters for most everything. I did have a fab table, steel with 1" steel top, 3x4', that got some heavy work. While the casters were satisfactory I needed a really solid base. I made some bracketts just inside the legs that had 3/4" threaded rod, thru rod couplings and jam nut backers. When I needit it to stay put I'd lower them and I could precisely level the table top.
domain
First is old set up, Second is Newest set up. :)
larry_g
oregon
Jim
Along the bottom of your bench is a rod/bumper looking thing. Is that a wheel lock of some kind or some other ingenious invention?
lg
no neat sig line
Jack Olsen
Los Angeles
I like workbenches -- and I probably have too many of them for a 20x22 garage.
Here's a tour. They're all cleaned up for the pictures.
1) Smallest is this little 3/16" thick welding table. I keep my table saw underneath it. Right now there's a band saw on top of it (that's on its way to being restored):
2) Behind it is my main bench, a solid-core door on a toolbox:
3) This big boy is an inch-thick steel-topped table for fabrication (and persuasion) work. That's a very sturdy cabinet underneath.
4) I've got an island type bench against the center pillar of the garage. It's birch butcher block. More storage underneath.
5) At the opening to the garage, I've got one I made out of 2" rectangle tubing.
6) Around the little sink, there's a 1/8" steel topped, also with cabinets underneath.
7) On the parking side, I've got a table I use to hold my router -- and sometimes for cutting with the miter saw. It's covered with two layers of 3/4" plywood.
8) Next to it is a 1/8" thick welding table.
Both of them fold up and out of the way when they're not in use.
9) And speaking of out of the way, I've also recently put in a hydraulic lift table, which comes up to the height of the other benches and can function as one, in a pinch.
10) Finally, there's a spare 1/8"-steel-table suspended up along the ceiling. This is the one I used to build the sections of my wrought-iron fence.
uxhamby
Here is mine in one of its cleaner moments lately:
jeffk14
GA
Home made bench, plywood and 2" x 4" legs
A bit OT, but it looks like you've got the same Hobart cover and the same "Deluxe" welding cabinet from Northern that I've got. Is that a Handler 187 under the cover there?
I just got my setup, so I can't evaluate, but I liked the deluxe cabinet better than some of the others. I got mine for $189.99 on sale. :thumbup:
PCO6
Newmarket, Ontario
Yes But.... Its always the same pic's in just about every other thread. :headscrat
I think that's because it's basically the same garage. :) If you follow any of Jack's threads or postings you will see that he has made lot of interesting improvements over time.
Morrisman
Angeles City, Philippines
I have nothing remarkable bench-wise, but I plan t build a heavy topped steel fabricating bench some time when my new 'shop is done.
What I want is solid and heavy, but with some sort of lever operated castor system to raise it 1/4" and allow me to move it, then drop it back solidly on four legs.
A bit like this one in construction, with storage and stuff underneath, welder maybe, but four inner castors that are out of the way..
Here's the bench in my last shop, but it has been rented out now we've moved overseas. Can't really see much, but it is back there, buried under rod parts. :)
regguy1
On Mount Olympus with Zeus
I've got the Hobart 140, the cabinet is very handy and keeps things neat and where needed..... OT?
Morrisman
Not much bench space but seems to be working out so far.
An old hand told me long ago: "you don't need a bench more than a yard or two long, 'cos all you do is pile junk on most of it".
He was right, I built a twelve foot bench, and only ever managed to work on 3' of it. :dunno:
Better to have a decent, reasonable sized, bench, and lots of shelves. :thumbup:
28HopUp
Lowcountry SC
Here's the one I built in our basement -
View media item 7859
I haven't put up the pegboard along the right wall yet, but I have managed to keep the work surfaces from getting cluttered up. (that's an accomplishment in itself!)
