Replacing Garage Threshold
tedfmcm
I need to replace my cracked garage threshold that has separated from the garage slab and the walls. It is a single car garage with a total area that needs replacing of about 17 inches in width after I will trim the slab to a flat edge with a saw that I will rent.
I have perused this forum and various other 'how to's' online and have gotten some basic understanding what I need to do. I plan on cleaning out the old area and then drilling into the slab where I can epoxy rebar into the original slab and then use a concrete 'cleaner' to make sure the new concrete adheres correctly. I will then build a form out of the asphalt fiber board (reinforced with 2x4's, plywood, etc.) between the asphalt driveway and the new concrete. After originally pouring flush, once the concrete starts to set up, I will scoop some out and create the slop needed to let water drain away.
Now here are my questions:
1. Should I drill and tie into the side walls of the garage that support the walls as well as the slab? If not, how should I treat that joint?
2. Seeing that the original slab is only 5 inches in thick and this new lip will be a high impact point, I was going to pour something thicker than 5 inches. Will this be an issue having the slab thinner? If not how thick should I make the threshold?
3. The asphalt driveway slopes a bit towards the garage as it is old and there is a fair gap (1-2 inches) between it and the foundation for the garage walls. Should I consider cutting into the driveway to take away the sloping section and just extend the threshold out even further (it would require extending the threshold about 5-7 inches more)?
I have posted pictures below and welcome some suggestions. Thanks in advance.
NUTTSGT
Northern Central Ohio
I'd hammer out the threshold and cut back far enough into the floor that you have good concrete to tie into.
I'd try to go atleast down 18", drill into the footer, run some vertical rebar, and drill into the slab floor and rebar that also, bending 90* downward. I'd run a couple pieces along the length of the threshold and tie those long pieces with the verticals and 90* pieces.
I wouldn't scoop out any concrete when you pour it, just make it an angle that slopes out. I'd also put a broom finish on it.
I'm not fond of that Asphalt fiber board either. You may need an driveway company come in after it's done and fix the gap you will have.
T
tedfmcm
Thanks for the suggestions. In lieu of asphalt board, what should I use for that gap? Should I just pour the concrete right up to it? Also, will it be possible to form an angled area of concrete was well as a flat 'lip' at the top of the old slab?
