Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Junior Member
I just washed and acid-etched my garage floor. I will prime it then apply solvent-based tan-colored epoxy.
I see a couple trails of ants in the garage as well as lots of individual ants randomly crawling around. I'm in Calif, so our ants are pretty small. Should I be concerned about their presence? Any way to get rid of them without re-contaminating the floor? |
#2 |
Senior Member
Can you spray outside around the exterior walls of the garage?
#3 |
Senior Member
Use a product called "Grants Kills Ants" It's a granular bait. spread it around the outside parameter of the garage and all your ants will be gone in a few days. Try to keep the bait dry. It's available in California, or at least it was last year when I lived there.
#4 |
Junior Member
I ended up ignoring the ants. I applied primer, epoxy and clearcoat on top of them
. After you apply the vinyl specks, you can't see any ants that are stuck in the clearcoat because they blend in. This is another good reason to use specks
#5 | |
Senior Member
Quote:
Just wait until the new floor is dry. Man, those ants will throw one wild part and invite the whole neighborhood. Well, aren't you too?? |
#6 |
Senior Member
#7 |
Senior Member
Heck ... I'd locate them, and use a tiny brush or toothpick with yellow paint and dot in their footprints right up to the tiny imbedded corpses.
#8 |
Senior Member
I have those piss ants all over my building. Irritating. I've sprayed the perimeter and ground a couple of times to little impact. The Mesquite trees seem to attract them. I'm more worried about the sap dripping off a couple of joists. Can't wait to try and get that off.
__________________
Chris - Merkel, TX http://raceabilene.com/kelly/hotrod GJ Build thread :http://www.garagejournal.com/forum/s...d.php?t=100482 |
#9 |
Senior Member
Try some diatomaceous earth spread around the perimeter.
| Thread Tools | |
| Display Modes | |
