slipjointed
- Joined
- May 31, 2011
- Messages
- 665
I just got my new Metric Wright grip set in from Epstein, and I must say, I'm less than thrilled. These wrenches do not represent the quality I've come to expect from Wright.
Even worse, there's a tag that says "Proudly inspected by...", if I had inspected these, I surely would not have been proud to send them on their way.
Just as some background, I've owned (and still do own) a good number of Wright tools, and have a certain expectation of quality. These do not meet that expectation.
At first look, they are very nice. They're packed in their usual high quality denim tool roll, nothing strange there.
Once you start to look closer, things get a little ugly. This 14mm has chrome peeling off all around the box end.
The 12mm has two large spots where the chrome has just peeled completely off, and a few water marks from improper cleaning before plating (which is why the chrome is peeling off). It isn't shown in the picture, but there's a spot alaong the beam where there's a forging ridge that was not cleaned off, and it is literally razor sharp. It would slice through your finger like butter if you tried to use the wrench.
Here's another water mark and a tiny bit of flaking chrome on the 13mm
The 9mm has the same water marks, but the chrome hasn't started to peel yet.
Just so everyone knows, this discoloration is not just the kind that will wash away. It's underneath the plating, and shows improper cleaning before the plating process.
I picked a sampling of blemishes, but there are more than what I have shown. I would say there are only 4 or maybe 5 wrenches in the whole set which I consider to be Wright quality.
I'm guessing that their final rinse baths were contaminated by too many wrenches passed through between cleanings.
I'm not worried so much about looks here, I'm worried about functionality. These wrenches will have essentially zero corrosion resistance, due to the faulty plating. Also, sharp edges on a hand tool are just plain inexcusable.
There's some other defects in the set, including heavy visible grind marks all up and down the 11mm wrench, to the point where the beam of the wrench is squared off on the side that was ground, and it no longer has a comfortable oval profile.
The largest and smallest wrenches in this set were all acceptable quality. To give an example of what I expect to see when I hold a Wright wrench:
I'm just a little irritated here, I'm not really sure what I plan on doing with these yet. I've been waiting literally for MONTHS and held back on buying any other Metric wrench sets, waiting specifically for the Metric Wright grip... being rewarded by this, is rather frustrating.
