Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#41 |
Junior Member
I really like the set up you went with in your shop. What pitch roof did you go with and how much head room did you end up with the attic rafters. I just got a qoute on a 4/12 pitch and it didnt seem to leave much room in the attic rafters.
#42 |
Junior Member
Wow, when did you get into my head? This is exactly what I want to build. Size and all. Can't wait to see it finished.
#43 |
Junior Member
How did you prep the site for using a pad slab instead of doing a foundation? Theres no worry about the slab moving a lot or cracking due to frost heaves?
#44 |
Senior Member
He built it on a rock quarry. It won't be going any where.
#45 |
The roof pitch is 6/12 giving me 65.5" from floor to the trusses, at least I can stand between the trusses when up there and don't have to be hunched over. As far as foundation prep, lots of compacted crushed stone.
#46 |
i like your loft. what did you figure out you are going to do with the doors for the loft or leave it open?
__________________
IN MY GARAGE: 06 CUMMINS ON 37'S, twin turbo... 91 WRANGLER ON 40'S,6.0... 09 SKI DOO RACE SLEDS HARLEY NIGHT TRAIN 05 SUZUKI DRZ 400 SUPERMOTO |
#47 |
Senior Member
very nice build so far....keep us updated!
__________________
_____________________________________________ NOW OFFERING CUSTOM garage/mancave license plate art! PM me or check out the classifieds! ALSO check out my NEW store below! http://www.etsy.com/shop/ThePlateFac...ef=seller_info |
#48 |
Framed in the loft this past weekend with 2x6,s and left a opening for a 42" insulated steel door which I had already cut down. I need to decide on a wall covering so I can start mounting electric boxes. Metal wall liner sounds nice but might dent up easily, but nice for water as I do want to wash cars in there, and pre painted. Plus I would need to fir the walls out to mount panels. I have a sample pcs of smart Panel, soaked it in water it swelled right up and when dryed never went back to original thickness, not overly impressed. Hardi Plank sample did soak up water but never swelled up, but is expensive
How about regular T1-11 painted, should hold up to abuse and should last indoors. Any thoughts would be great, I know wall covering are debated quite a bit on here.
#49 |
t-11 is whats in my dads pole barn. we stained it the same color as outside. its lasted 10-12 years with no problems. and he races dirt oval race cars. lots of abuse
__________________
#50 |
Slow progress, installed subpanels in the house and garage, now have power in the garage
Installing the outlet boxes and planning for the lights. This part I hate becuase I always think I forgot something or could have been layed out better.
#51 |
Rough wiring is complete, decided on 20 (48" 2 bulb T-8 fixtures) 12 in the bays parallel to cars and 8 fixtures in shop area. I hope I coverd everything for wiring. Attic door is installed, I thing it will work fine.
#52 | |
Senior Member
Quote:
__________________
My 30X40X12 After Fire Rebuild http://www.garagejournal.com/forum/s....php?p=1947185 |
#53 |
Passed rough electrical inspection, wired some temporary pigtails and put in GFI protected outlets. Sorry guys slow progress, trying to finish out of pocket.
#54 |
Had a two month break getting caught up on the house and yard work, time to start the soffits, I used metal and a little disapointed in the look.
#55 |
Finished the soffits and have moved on to the cultured stone for the front
#56 |
Finished the stone work , sill's installed and stone grouted. I didn't enjoy this step too much.
#57 |
Today I started the back wall with steel siding, hopefully a little better then the stone work.
#58 |
Finished the back wall today, everything went well. The panels where orderd to size so I had no cutting which really sped things up.
#59 |
Worked on the south side this weekend, pre-cut lengths worked very well again. Work went into slow motion doing the upper level cutting along the gable end. Dosen't help working alone either, I have to congradulate those on this site who have done a lot of the work themselves.
#60 |
Looking for votes on siding for the north side (side with entry door and window). Steel or cedar, cedar will also go sbove the stone. Problem I'am having is as you pull up to the house you primarily see this side and the front. Initially I wanted the garage to be totally maintenance free as I have the house to worry about. Thanks
| Thread Tools | |
| Display Modes | |
