Show Off Your Power Tools
Monte
Germany
The power tools i started with 7 years ago:
Meanwhile i added several tools:
Makita 6270 cordless drill
12 Volt, 2.0 AH, 0-400/0-1300 rpm, made in China
Panasonic EY7441 cordless drill
14.4 Volt, 1.5 AH, 60-400/200-1.350 rpm, made in China
Metabo SBE 1010 percussion drill
1010 Watt, 0 - 900 rpm/0 - 2.600 rpm, 13mm chuck, constant electronic, safety clutch, made in germany
Dewalt DW 217 drill
675 Watt, 0-4000 rpm, 10mm chuck, made in England
Milwaukee HDE 13 RQX drill
950 Watt, 13mm chuck, 0-525 rpm (Load), spindle lock, made in USA
Fein ASke 636 Kinetik drill
320 Watt, 0-1570 rpm, 10mm chuck, made in germany
Bergin SB 4001 percussion drill
400 Watt, 0-2550 rpm, made in Germany
Metabo FSX 200 Intec orbital sander
5"/125mm, 240 Watt, 9500 rpm, made in China
Metabo SXE 425 Turbotec orbital sander
5"/125mm, 320 Watt, 4.200 - 11.000 rpm, made in Germany
Rupes SL 42AEV sander
550 Watt, 3000 - 7000 rpm, 400 x 70mm pad, made in Italy
Atlas Copco AGV 16-125 QXC angle grinder
5"/125mm, 1520 Watt, toolless adjustable guard, 11.000 rpm, Autobalancer, constant electronic, made in Germany
Fein WSG 13-70 E angle grinder
5"/125mm, 1200 Watt, 2500 - 7000 rpm, constant electronic, made in Germany
Fein WSS 14-125 angle grinder
5"/125mm, 1200 Watt, 10000 rpm, constant electronic, toolless adjustable guard + disc exchange, made in Germany
Bosch GWS 14-125 CE angle grinder
5"/125mm, 1400 watt, 2500-11000 rpm, constant electronic, toolless adjustable guard + disc exchange, made in germany
Makita 9565 HZ1 angle grinder
5"/125mm, 1100 Watt, 11000 rpm, toolless adjustable guard, made in England
Metabo W 8-125 Quick angle grinder
5"/125mm, 800 Watt, 10000 rpm, toolless adjustable guard + disc exchange, safety clutch, made in Germany
Hitachi G12 SR2 angle grinder
4.5"/115mm, 650 Watt, 11000 rpm, made in China
Suhner UWF 10 angle grinder
5"/125mm 1000 Watt, 10000 rpm, made in Germany
Suhner UWC 7 / UWC 10 angle grinders
4.5"/115mm, 500 Watt, 7000 rpm / 10000 rpm, made in Germany
Flex L 1109 FE angle grinder
5"/125mm, 1000 Watt, constant electronic, made in germany
Suhner UWC 20-R grinder
2"/50mm, 500 Watt, 9000-20000 rpm, constant electronic, made in germany
Flex L 2108 VC angle grinder
7"/180mm, 2000 Watt, 8500 rpm, made in germany
Flex L 3403 VRG polisher
160mm, 1400 Watt, 1100-3700 rpm, constant electronic, made in germany
DeWalt D28886 die grinder
710 watt, 7000 - 27000 rpm, constant electronic, spindle lock, Made in Germany
Suhner USC 25-R die grinder
500 Watt, 11000 - 25000 rpm, constant electronic, made in germany
AEG Step 90 jig saw
570 Watt, 1000-3200 rpm, toolless blade exchange, made in germany
Bosch GHG 660 LCD hot air gun
2300 Watt, 50 – 660 °C, 250 – 500 l/min, LCD display, programmable, made in czech republic
Steinel Gluematic 3002 glue gun
200 Watt, 206°C, 16 g/min, made in romania
Proxxon Micromot 50 grinder
40 Watt, 5000 - 20000 rpm, made in EU
Kärcher NT 361 Eco vacuum
1380 Watt, 57 l/s, 235 mbar, power filter clean, made in Italy
some tools i owned but sold:
Bosch PEX 400 (Swiss made) which i sold in favour of the Metabos
Milwaukee "AGS 15-125 C" angle grinder (german or czech) which i sold in favour of the Fein WSG 13-70
some tools i bought from the flea market:
Lesto/Scintilla (Bosch)
Duss
Bosch (swiss made)
Black + Decker (made in Germany)
Flex polisher/sander (2000 rpm)
Fein
Metabo
Stuey
28m above sea level
I don't think that even I can beat that between my personal tools and the review shelf.
Also, please nobody quote Monte - doing so will likely cause my web browser to self-destruct.
Monte
Germany
All I have is cordless tools, is that the same thing?????????? LOL
yes !!!
@ Monte ... which one is the best grinder among those you have in terms of overall performance?
Thanks
Difficult to compare because they all have a different power output so you can´t compare them. I need to buy angle grinders with the same power let´s say 14 AMP and then compare.....but no money for that :)
The Bosch grinder seems to be the strongest so far (1400 Watt (about 13 AMP) the Atlas Copco has more input power + slightly more output power but from a subjective view the Bosch tool doesn´t seem to bog down under load as much as the Atlas grinder. So maybe the electronics regulate better, different wound motor, maybe heavier rotor = more torque etc. Difficult to say..... But overall the Bosch is nice, slimmest motor housing and the new ones have a toolless adjustable guard like the Metabo (with a small lever) But i think you already made a good choice !! Metabo just upgraded all their grinders by 50 watt so the most powerful one now has 1450 Watt for example instead of 1400. They´re also comfortable to hold and have low vibrations and their side handle is not that clunky compared to Bosch + Makita etc.
Monte wins.
riceh wins :)
NJHandyGuy
Brick Nj baby
just the ones i have in the truck for right now
Monte
Germany
The power tools of my father:
AEG HBSE 100 belt sander
AEG EXE 400 orbital sander
AEG VSSE 260 sander
AEG 450 Watt percussion/hammer drill
AEG 1000 Watt percussion/hammer drill
AEG Pneumatic 3000 Super X2 rotary hammer drill
AEG WSLE 115 4.5" angle grinder
AEG WS 1700 S 7" angle grinder
AEG WSLB 230 X 9" angle grinder
AEG OFE 630 router
AEG H 750 planer
AEG K 55 E circular saw
AEG STEP 600 X jig saw
Bosch PMS 400 PE multi saw (takes jig saw blades)
Bosch PDA 120 E delta sander
Bosch PVS 300 AE vario sander
Bosch PSE 180 E scraper
Bosch PSR 18 LI-2 cordless 18 Volt Li-Ion drill
Bosch "IXO" cordless Li-Ion drill
Bosch "Prio" cordless Li-Ion delta sander
Steinel HL 1500 S heat gun
Wagner W 180P electric paint gun
Wagner Mistral electric paint gun
Black + Decker DN 520 electric shears
Black + Decker cordless grass cutter
Wen soldering gun
Parkside stapler
Monte
Germany
forgot to post my fathers Proxxon "Dremel" tool:
his Fein Multimaster
Wagner Motorhammer
the tool inserts for the "Motorhammer":
needle scaler, and a flat and curved wood chisel
Monte
Germany
It has a cord so it´s a power tool...? :)
"Weller" soldering gun - made in Holland
"Ersa" soldering gun
Mr Ratchet
Here's mine. In the rack in their cases and then laid out.
Newer grinder not in the laid out photo.
kyrbz
midwest US
One I couldn't live without - Festool Circular Saw System
And a new one I just got this week - Baileigh Portable Bandsaw
up_in_the_air
Christchurch, New Zealand
Some of mine:
