Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-08-2011, 01:32 PM   #1
CaptainRay
CaptainRay's Avatar
Default Need help on a compressor shed
I'm putting my compressor in a shed outside my shop, just too noisy to be inside. My problem is I need to put the shed about 6 feet from the shop to avoid the watershed and cement surface drain. I can put the electric underground and come up to go into the shed from the shop.
My problem is the air lines really need to go in at the level they come out of the compressor, mayby at a down angle into the shop to hookup to the filter to avoid water collecting and sitting in the pipe. Anybody had any problems with winter weather and lines that are exposed, maybe with that foam insulation that slips over the pipe?
Suggestions would be appreciated.
My shop construction here:
http://s1134.photobucket.com/albums/...aptainRay1964/
CaptainRay is offline   Reply With Quote
Old 11-08-2011, 02:17 PM   #2
bobemmerich
Senior Member
bobemmerich's Avatar
Default Re: Need help on a compressor shed
What about building a small room inside the shop for it, instead?
bobemmerich is offline   Reply With Quote
Old 11-08-2011, 02:23 PM   #3
TWX
Senior Member
TWX's Avatar
why not put the compressor up a bit, on a metal frame?
TWX is offline   Reply With Quote
Old 11-08-2011, 02:41 PM   #4
CARS
Senior Member
CARS's Avatar
CaptainRay,
I have often wondered the same. A collision shop opened up in town this summer and he put the compressor in a adjacent garage with the air line (pex) run under ground. I will be sure to report how that works here in MUCH colder MN.
Sorry I don't have answers. I would think a large pipe (1"+) properly insulated would have no problems. There isn't that much water in a line.
Be sure your compressor tank is on some sort of timer drain so you don't have to walk out to the "shed" every half hour on the humid days.
CARS is offline   Reply With Quote
Old 11-08-2011, 03:16 PM   #5
larry_g
Senior Member
http://www.garagejournal.com/forum/s...d.php?t=109062
Read my post in the above thread.
lg
no neat sig line
__________________
My Shop build thread
Wise people talk because they have something to say. Fools talk because they have to say something.
larry_g is offline   Reply With Quote
Old 11-08-2011, 05:17 PM   #6
bt34
Junior Member
bt34's Avatar
A large amount of comp noise comes from the inlet side so see if you can poke the inlet pipe through the wall to the outside....Then put on old style aircleaner on it and that will filter the air and also quieten it some more.
cheers Bryan
bt34 is offline   Reply With Quote
Old 11-08-2011, 06:03 PM   #7
PT Doc
Senior Member
PT Doc's Avatar
I've been looking into an intake silencer and solberg makes a unit slcr100 (100 denotes 1") and they claim 15-30dba reduction. That is huge if it can do that.
PT Doc is offline   Reply With Quote
Reply
Tags
compressor, lines, shed
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
