The_Tango
Not going to do a lot of cutting but which would be the best for cutting steel for welding projects? Welding cart, Work tables, Small projects. Square tubing & Angle.
(cost is a concern)
(cost is a concern)
what about the various 'cold cut saws'? looks like a chop saw but cuts nearly burr free and doesn't throw chips everywhere. i know milwaukee makes one, and i think there is an inexpensive one ('rage'?) thats around $200.
ahm
Motorized hacksaw (reciprocating type) is really s-l-o-w.
If I go with a bandsaw if would be "horizontal". The cheap HF & NT ones get very bad reviews - Nothing on local CL.
However, you can walk away & let it do the cut while you do something else..Motorized hacksaw (reciprocating type) is really s-l-o-w.
You could definitely get by with only that saw. The tradeoff is speed. If you're careful with setup on a band saw it can be very precise.Jack - which do you like better; the toothed chop saw or the porta band with the base? I already have a porta band and am going to get the Swag base. I am hoping to be able to get by with just one metal cutting tool due to space. Do you think you could have gotten by with just the porta band?
