New from Macon Ga. 50x38 shop. Need wall ideas
ChrisBrooks
Macon Ga.
Great board everyone. Chris Brooks here from Macon Ga. I built a 50x28 shop with rooms on one side. One wall is sheetrock. The other is partical. Both look bad. What I want to do is use thin beadborad 4x8 then roof tin/beadboard again, etc. Ceilings are 10'. I'll stop at 8' then box in 2' on top with a painted boxed frame look to install photo frames.
My shop used the Flat tin roofing that overlap at the ends. I want to use the same on my walls in between beed. I'll send photos later of my shop. Any ideas of your shop that might be simular, I would like to see them.
Talk to you soon I hope.
Wingnut65
Tampa Bay, FL
Welcome to GJ, Chris. Nice size shop you have. Sounds like you have good plans for your place. Be careful around here... surf too much and your plans will be changing. Which won't be a bad thing. It will be a better place since you found us. Good Luck on your project!
