Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
Eh, I figured I needed a name, so that's it, lol. Mainly do to the fact I'm restoring a 71 JD110. It still needs to be cleaned up, the ceiling finished, insulated and better organized. Heres it when I started:
After we had a 40' dumpster in, in looked a lot better. I also got a more compact cherry picker, and 3 big Husky tool boxes and moved the compressor into the attic. ![]() ![]() ![]()
#2 |
Senior Member
Husky boxes look pretty nice. You are off to a great start, should be a very nice space once your done with it.
No photos of the JD?
__________________
~Scott My Shop Bad Company - A one way ticket to the dark side! A promise not kept, is the road to exile! It Ain't real music without guitars! It's not what your wallet bought, but what your two hands built! |
#3 |
Senior Member
I think you need to post a picture of the deere.
#4 |
Senior Member
It needs a John Deere Sign or two as well ...
__________________
#5 | |
Senior Member
Quote:
Pics to come, lol. Those are in the house toll I finish cleaning and organizing. |
#6 |
Senior Member
Here's the pics.
71: ![]() 69: ![]() The POS L120: ![]() My Craftsman: ![]() Bolens 1050:
#7 |
Junior Member
Nice GT's ya got there. Do you vist weekendfreedommachines.com or GTtalk.com any?
We have 2 '77 210s and a '75 214 with electric lift. |
#8 |
Senior Member
Thanks. I got confused when I was on weekendfreedommachines, but I am on mytractorforum. I'll check out GTtalk here soon. I'm on the lookout for a cheap 4xx series so I can junk the L120. It's more of a money pit than my 110, lol.
#9 |
Senior Member
Nice work! I really like the older JD 300 & 400 series they are real tanks!
#10 |
Senior Member
Thanks, I really need to get a few more tools/equipment and pics of its current state. I plan on adding DirecTV and internet out there too.
#11 |
Senior Member
Ok, a few questions. First two are similar. How should I run the cable and internet to the garage, and what should I use for the ceiling and in the attic as a floor?
#12 |
Senior Member
bump for advice. and ill get better pics tonight
#13 |
Senior Member
the Cable you don't have alot of choice on, though if its a long run you might have some signal loss - its fixable but ...
Ethernet, well I'd suggest wireless.. OSB should work, just be sure to get it painted...will reflect a lot of light, and its cheap..
__________________
#14 |
Senior Member
the cable is only about a 50-60' lead from the dish. and for the wireless, know of any good signal boosters? we already have wifi, its just weak out there. and how thick of osb should i get?
#15 |
Senior Member
nice collection of GT's. I feel your paint with the L120, i've got a L100 that just got replaced by a 1023E, much more machine.
__________________
11 F150 FX4 EB | 11 Equinox LT V6 AWD | 89 Scirocco 16v | 80 Camaro Z28 | 37 Plymouth | 11 John Deere 1023E | 30 x 40 Shop, heated and cooled |
#16 |
Senior Member
No Clue on the signal booster. check with some place like newegg.com or a local computer store - they can probably help you on the latest and greatest. I have a friend that deals with networking and such, I'll give him a shout and see what he suggests (or point him to this thread)
For the OSB.. are you going to be walking on it? if so, the thicker the better, if its just for the ceiling, 1/2 should do -
__________________
#17 |
Senior Member
More GREEN stuff please !
![]() ![]() ![]() ![]() Thanks
#18 |
Junior Member
Hey Good start on the garage.
Got the message on you having issues with the signal in the garage. One thing you can so is try to move the unit closer to the garage. another thing you can do is just run a cable to the garage, but then you would be tethered to a cable then. What I would do is pull a new cable to the garage and install a second Wireless unit. Then you can set it up out there and have coverage in the garage. You can configure the 2 wireless units to be on different channels and get coverage thru the whole house. I am going to pick up a second wireless unit for my house as I have this same issue. my antenna is in the front of my house, and I have crap coverage in the garage which is at the back of the house but I can get great coverage on the porch and out on the street where I park. If you have a really long run for you TV go with larger gauge cable so you will have good signal. I would also go with a quad sheild cable so you don't have as much line loss. I run RG-11 quad sheild from my dish to the dist. board, then RG-6 Quad shield to the Receivers. Use a good connector on each end and you should be fine. Hope that helps. if you have any other questions, let me know I will do what I can. Arin |
#19 |
Senior Member
thanks for all the advice. the computer is going to be a standard desktop, the main reason i want wifi is for my ipod touch or my phone, plus it may be easier than running cable, so ill look into signal boosters first. and the dtv cable, ill get the best i can afford, it would be nice to have tv out there again, but even if i cant do that, i can always use the computer once it is set up. and on the osb, it will just be used for the ceiling, and possibly the walls once i get more storage. i will have plywood floors in the attic to set stuff on. i really need to add outlets by the workbench. right now that is just an extension cord... :/ also, ignore the poor grammar, im sending this from my phone, lol.
#20 |
Senior Member
| Thread Tools | |
| Display Modes | |
