desiccant air dryers?? anyone?
socapots
Canada
Hey all.
Just wondering if anyone has been using some kind of desiccant air dryer.
I have one like the add below, for some time and it seems to be doing what its supposed to. But i am supposed to change out the desiccant every year or so. Just wondering if anyone else uses this type.. or if people have found real problems with them that stopped them from using it. I also have a filter down the line from this.
http://www.princessauto.com/pal/product/8055757/
isaac338
Halifax, NS, Canada
I have that same dryer. It seems to work well. You can put the pellets in the oven for a while to dry them out instead of buying new ones.
PCO6
Newmarket, Ontario
I have that unit and agree that it works well. PA has it on sale for about half that price occasionally. I plan to make a dedicated one for my sandblast cabinet. They are pretty basic and can be made from standard threaded pipe and fittings.
bmwpower
How do you keep the dessicant from getting into the air line?
KCarGuy
50 miles outside Chicago, illinois
I use the Dessicant Air Driers as a "Last Defense"...
I have a Auto Drain on my Compressor...A Water Trap before my Regulator...and 3 Main drops in the garage, each with a Dessicant trap.
I have used these for the last 22 years and they work great.
One is in line before the Sand Blaster Cabinet...but I drilled and tapped the "In" and "Output" for a larger Air Line.
The Dessicant is Bright Blue when it is new...and slowly turns pink as it traps and holds moisture.
I have Three 5 Pound cans of it in a Cabinet...It will last me another 20 years.
Nothing like Clean, dry Air for your Tools!!!
socapots
Canada
never thought about the oven trick.. makes sense.. and i remember hearing about that trick for Those silica beads you can use to keep your cigars humidified.
LOL, Yeah they are pretty basic. I got the one i have when it was on sale as well.
This type of desiccant are large puck like things.. like those little pucks you put in the floater for your hot tub to keep the bromine/chlorine level up.
I like that idea of one on each drop. my place is pretty small so one 50 ft hose will go everywhere. lol. I dont see myself doing much piping except from the compressor (soft line), to the dryer and a filter. and a regulator before it all.
Only reason i picked this one up to being with was to keep the air nice and dry for the Plasma cutter.
Andamo
Trinity, Florida
Check and make sure those pellets are able to be regenerated. Many will break apart when they're heated enough to drive out the water. A good alternative to the pellets is molecular sieves. Use these along with a small layer of the blue indicating Drierite at the outlet of the dryer. When you see the indicating Drierite turning pink, just get rid of it and put the sieves in a oven and bake them out. Follow the directions for the sieve usage and you can use them over and over again. They do have to be regenerated slowly at moderate temps, but that keeps them able to be re-used over and over. Mole sieves are specific as far as what they'll remove from the air or liquid passing across them. Make sure you get the ones for water only.
PCO6
Newmarket, Ontario
The dessicant and the sand won't mix. I simply plan to add a dessicant dryer to the air line as a "last stop" before air enters the sand blaster.
The photo below isn't very good but you can just see part of my current dryer in the background (yellow vertical pipe). It dries the air lines to my entire garage. I want to add a separate, smaller dryer to the line so the air entering my blaster is as dry as possible.
PCO6
Newmarket, Ontario
HAP - That looks good. :thumbup: A couple of questions ...
1 - It looks like you have added "windows" to keep an eye on the dessicant as it discolours. What material did you use?
2 - Do you have a drain on the bottom of the dryer?
Strouty
Southern Maine
HAP, can you give details on how you made that? It looks pretty straight forward, but I am always interested in drier air.
HAP
NE North Carolina
PC06,
I ordered the ports form MSC, thay are rated for like 400psi and 500* or something like that... I do have a drain at the bottom; never get anything out of it. I run a blast cabinet, air/hyd press, powder coat gun and your typical air tools. I have gone a year before having to to reguvinate the stuff.
You need to use a screen and some type of fabric to keep the desiccant particles out of the lines.
HAP
W-Cummins
Iowa
Here is the one I'm running it regenerates the desiccant for ya
William.....
FatFenderBowTie
Manitoba boonies
Socapots, I am running the same dryer as you have and have had no problems with the dryer…easy to maintain, but the issue I have found is PA seems to run out of the pellets periodically, usually when I am looking for them.
socapots
Canada
Yeah. I noticed that about them being out from time to time.
Another question for you guys about this dryer. It says right on the dryer to have it at least 25 feet away from the air compressor. I assume this is for cooling. Anyone have it closer? Have you experienced any problems as a result?
PCO6
Newmarket, Ontario
Mine is only about 3' from my compressor but it's connected by about 25' of curled up rubber air line. It seems to work fine. I plan to replace the rubber air line with about 25' of pipe which will cause the air to travel that distance before it enters the dryer.
porcupine73
Buffalo, NY USA
I've got a Wix aquachek desiccant drier inline. It seems to have worked very well, have not seen any water in the drains downstream of it. But the filter replacement cost is probably more than just buying the bulk desiccant.
socapots
Canada
i had mine hooked up with about 10 feet of rubber hose.. seemed to be fine as well. Just not sure if it could have been better.. ive never noticed any moisture in the line. But maybe it as all temperature related.
CARS
New Ulm, MN
I really think that home made dryer should be a "fabrication section" write up. I could always find drops to replace/add on to.
gixer007
Va
Any details on what you used for a screen and how you set it up in the pipe?
Thanks
brats.n.harleys
Portage, IN
made this one out of a 2 gallon compressor tank. has 25 pounds of dessicant in it, screens welded into the fittings, theres a 2'' fitting on top to take out the dessicant every once in a while and dry it out. the cheapo filter thing on top isn't there anymore.
bobcat
The only areas we had issues with in plants with the dessicant driers was if there was a sudden surge of air ( opening a line suddenly ) , you could get some dessicant carryover into the tool/system if the dryer didn`t have a good safety factor on cfm usage .
The other thing to realize is that the dryer will not dry the air after it comes out of the dryer . We used to see plants put in an expensive unit and then run lines to equipment as much as 50 ft away and then complain that the dryer wasn`t working . IMO , always put a filter before the work station ... could save some headaches later . Is it certain you will have these issues ? ... no , but these are two areas to pay attention to .
HAP
NE North Carolina
Thanks
I used 2.5" galv. pipe 48" long. Two T's with 2.5 to 1/4" reducers. Inside I simply epoxy'ed a washing machine/pressure washer hose inlet screen over the air inlet and outlet fitting holes on the inside. Any type of wadding (old sock material) will work to catch the fine particulates (a must).
The reason I went with 2.5'" pipe is because anything larger than that diameter is not rated for pressure. During my research of components, they did not offer working pressure maximums above 2.5". So, I just stuck with common materials.
My prototype build was made out of clear 2.5" PVC and looked really cool. However, we all know about the durability/dangers of PVC and compressed air.
More details available is desired...
Jamesbbh
Pensacola, FL
Not dessicant but cheap and easy to do nonetheless. I had never seen anyone do this so I decided to try it out.
Compressor-->Yellow tank-->Copper water trap-->bottom of red aux. tank-->out of the top of the red tank to filter/regulator then to whatever tools you wish.
1/2 Copper coil strapped to the shop AC window unit with a 90 bend and ball valve to drain. By the time the air fills up the first tank and makes its way through the trap and fills the second tank it is beyond cool enough to condense all water out of it. I run a plasma cutter very regularly with this and have yet to see any water at the tools. I still drain the yellow tank pretty regularly and purge the copper coil everytime I use something. Water comes out of it everytime :beer:
bmwpower
I was referring to if you built one, how you would you keep the dessiant from getting into the lines. Seems like you would need some sort of screen or something, but wasn't sure if there was a legit plumbing piece that did this.
PCO6
Newmarket, Ontario
In the Princess Auto unit in post #1 there is a small retaining plug / screen at each end of the tube. It would be easy to duplicate with a small wire mesh like window screen, a sink drain screen or even coarse steel wool. I use the large dessicant pellets like in post #2. They are about the size of sugar cubes. They do break down a bit but I have never had a problem with the bits getting into the air stream and eventually mixing with the sand.
