Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#41 |
Senior Member
Gravity bleeding works OK if it will bleed. Some will, some won't. You can pinch off the rubber lines at the wheel. Pinch them off at the chassis end. Pinch them all off, see how the pedal feels. If its at the top, then release them one at a time, see which one lets the pedal go to the floor. If after pinching them off, the pedal is still soft, it is an indication the master cylinder is out. Most vehicles, by pinching the hoses, you have made the brake system a smaller unit, so some air is more apt to compress a little making a full pedal, or a firm pedal. There are tools made for pinching the lines off, that have rounded edges. I have done it with needle nose vise grips but you have to be carful.
#42 |
Senior Member
Thanks jimindm! I will try that. I think I know those tools you are talking about. How much do they cost?
#43 |
Senior Member
http://www.tooltopia.com/otc-tools-4506.aspx
I think that some use needle nose vise grip with rubber hose around teeth. |
#44 | |
Senior Member
Quote:
Brake hose is a hydraulic hose. It has steel braiding inside the rubber, which will permanently deform if pinched shut. I wouldn't drive around in a car that had had its brake hoses crimped shut. It's just a bad idea. The only time I crimped my brake hoses shut, was when I was doing a something that involved replacing the hoses later, so I pinched them to make less of a mess. |
#45 |
Senior Member
I've seen people pinch flexible brake lines all the time with vise grips.
__________________
Adam's Auto Advice - Auto Awesomeness Singing Dogs - Yup, Singing Dogs! :) CarNewsCafe - The best car news around |
#46 |
Senior Member
Going to try to Gravity bleed today... it's going to be messy!
#47 |
Senior Member
#48 |
Senior Member
I would not recommend driving around with them pinched off. I meant before he bleed them.
When you are in a pickle i have done all kinds of things that I would not reccomend. I have driven cars with nothing but ebrakes, broken clutch cables, no accessory belts, the list goes on. I know the limits, its only to get to the shop. Its not across the country, over mountains, etc. You have to know your limits, otherwise that is what towing services are for. A persons ability changes that limit. Some should never even be allowed to open a hood. Others could work beside me. |
#49 |
Senior Member
#50 |
Gotta be real careful bleeding the brakes on some of the newer cars. If you let air into the system via the master cylinder, you might have to take it to the dealer to have it bled using a dealership scan tool. Depends on the vehicle though...
#51 |
Senior Member
I use a pressure bleeder from www.motiveproducts.com it makes brake bleeding a one man operation. The pressure bleeder pressurizes everything including the brake reservoir. Pump it up, and crack the bleed screws open one at a time. Works great! You can get the pressure bleeder through Summit or direct from Motive Products.
#52 |
Senior Member
im having issues getting the brakes bled on my 1991 C1500 now...I replaced the flexible brake lines and master cylinder...now I only get a good firm pedal if a pump the brake's a time or two before applying them......
what did I screw up? |
#53 |
Senior Member
Gravity bleeding fixed it!
#54 |
Senior Member
Location: Moundsville, WV, 15 miles South Of Wheeling WV
#55 |
Senior Member
Didn't need a new Master Cylinder! Of course it will probably go out next week!
| Tags |
| air, bleeding, brake, honda |
| Thread Tools | |
| Display Modes | |
