Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Display Modes
Old 02-22-2012, 09:46 AM   #1
LouG
Default How to replace ignition lock cylinder?
My DD is a 1997 Toyota Camry, and the ignition lock is starting to go (it's getting stuck when trying to turn the key past the ACC point).
Any techs here that can tell me how to go about replacing this? I've searched the web but despite this being a fairly popular issue, I haven't come across much help. From what I have found, the lower plastic panel is removed, the key is turned to the ACC position, and at that point there's a pin that can be removed, thus allowing me to pull out the cylinder. I'm getting labor quotes of around $200, and that plus the $250 for a new cylinder and re-coding for my key, it's getting a bit pricey.
__________________
1992 Mazda Miata Sunburst Yellow #1122 of #1519: 18k miles.....and counting......
LouG is offline   Reply With Quote
Old 02-22-2012, 10:49 AM   #2
Mr.Nutcase
Senior Member
Mr.Nutcase's Avatar
Default Re: How to replace ignition lock cylinder?
The pin is pushed using a pick, while its in acc, the ign cylinder slides
i have done a 1996 Camry, they are the almost the same....
__________________
cheap tools give me pain and headaches...... he he
Mr.Nutcase is offline   Reply With Quote
Old 02-22-2012, 11:05 AM   #3
LouG
Default
How long do you figure for removal and replacement? It would appear even a willingful novice can make this repair - would I be correct?
__________________
Old 02-22-2012, 12:26 PM   #4
taterdog
Senior Member
go to advance, buy a lock cylinder. they come with little pieces of paper with step by step instructions.
taterdog is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
