Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 04-07-2012, 02:43 PM   #61
red92s
Senior Member
Default Re: anybody here willing to machine some gears?
You can get parts rapid prototyped in materials that will approximate ABS and nylon. I'd guess that the first part would be $50, with additional copies made at the same time around $15.
DLMS, as previously suggested, gets really expensive really quickly.
http://www.finelineprototyping.com/
red92s is offline   Reply With Quote
Old 04-11-2012, 10:32 AM   #62
chad99
Has the vehicle been in a wreck?even what you may consider to be a minor fender Bender can manifest itself in strange ways with today's full unit body type construction.Nylon and various polymer gear sets have been used for decades,without catastrophic fail rates for low torque applications.If you are consistantly shearing gear teeth the answer is to correct your binding linkeage or frame not to construct.steel gears so the.whole assembly can further self destruct itself.
chad99 is offline   Reply With Quote
Old 04-11-2012, 11:32 AM   #63
superspec
Senior Member
no wrecks. its a fairly common problem for this car.
not a big deal, ill just keep it closed haha. i have 2 of these cars and the first one i bought new and refused to have a sunroof. the 2nd was bought used from a friend so i know its history.
superspec is offline   Reply With Quote
Old 04-11-2012, 10:23 PM   #64
Okie Pete
Senior Member
Okie Pete's Avatar
Check around and look for a shop with a plastic printer. A friend showed me a turn buckle with hemi joints for ends that was sent to his employer as a demo piece. The hemi balls moved . It had lefthand and righthand threads that worked. They can also spray other materials also.
__________________
Keep Your Mind in the Middle , John Wayne
Okie Pete is offline   Reply With Quote
Old 04-13-2012, 11:02 AM   #65
andywander
Senior Member
Is it always the same gear that breaks?
I might be able to machine a few of those....
andywander is offline   Reply With Quote
Old 04-13-2012, 12:23 PM   #66
superspec
Senior Member
in the set that i have there are 2 gears broken.
Old 04-13-2012, 03:48 PM   #67
68rustang
do you have a CAD file or are you expecting somebody to do all the work if you send the gears?
Being it is just a sunroof it shouldn't be too hard to get something serviceable without going crazy.
68rustang is offline   Reply With Quote
Old 04-13-2012, 07:36 PM   #68
superspec
Senior Member
i have zero in the way of files and only a set of gears which 2 of the 4 or 5 are missing teeth or cracked.
Old 04-13-2012, 10:09 PM   #69
andywander
Senior Member
"...4 or 5"? I only see 3 gears(not counting the worm) in your photo.
Old 04-14-2012, 06:44 AM   #70
superspec
Senior Member
there is one under the top gear next to the penny
Old 04-23-2012, 01:22 PM   #71
RobSmith
Senior Member
RobSmith's Avatar
Send a message via Yahoo to RobSmith
get onto "Model Engineers Workshop". They're in England and their hobby involves making machines and tools for their workshops..gear cutting is 'just another job' for them. They like fitting computer controls to their machines as well.
RobSmith is offline   Reply With Quote
Old 04-24-2012, 04:24 AM   #72
fastbroshi
I'm late to this party, but you can cut gears a lot quicker on a lathe with a Hardinge dividing head and some cutters. Don't see them much anymore so it's not surprising it hasn't been mentioned. Here's a quick walk through. Hell, maybe the author could do it for you.
http://www.youtube.com/watch?v=pIg8I...l31BQm2hcVpiw=
fastbroshi is offline   Reply With Quote
Old 06-22-2012, 06:04 PM   #73
Russell
Senior Member
Russell's Avatar
If nylon/plastic is OK contact this guy, that's what he does: http://www.odometergears.com
Here's the process of cutting gears at home which is not hard, just time consuming and of course you have to have both a mill and a lathe - or a combo machine:
http://www.youtube.com/watch?v=xRmQpSGUAY8
Russell is offline   Reply With Quote
Old 06-22-2012, 09:04 PM   #74
SVE Performance
Try here http://gearsmade.com/ .Bill
__________________
Wrencher of all things jeep
sveperformance.com
SVE Performance is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
