OTC chargingy, starting and battery tester
t100
up for sale is a fully functional OTC SPX Minuteman Plus tester. nothing wrong with it, only reason for sale is I don't use it much.
retail is about $2200. I believe the capacity is 1500 amps.
$400 shipped lower 48 WITHOUT the cart.
if you want the cart, you need to contact me because the shipping is gonna be a lot.
T
t100
$400 include the cart if you pick it up.
a short vid on how it works.
features:
-Tests batteries, alternators, regulators, and starters. Direct-from-battery tachometer feature gives RPM readings without complicated hookups to ignition system. Also, ammeter/voltmeter capabilities.
Evaluates discharged or charged batteries in one minute. Tests all 12-volt automotive and heavy-duty batteries with cold cranking amp ratings of 100-1500. Has its own internal battery; no external power source needed.
Checks charging system at high RPMs and at idle, and stores the data. Results show regulator volts, peak amps, and diode condition. Utilizes wave form analysis when testing alternator diodes; more accurate than 'ripple voltage" tests.
Displays cranking volts and amps, indicates either "Good Starter" or "Bad Starter."
