I bought a chop saw.
bad_idea
Pasquotank, NC
I bought a Dewalt 14" chop saw from home depot the other night. I like the tool, it is much nicer than using a 4 1/2" grinder for all my cuts. But the clamp/ angle guide is severely lacking in comparison to my miter saw as far as precision of angles.
So I figure if I am finding the saw lacking in this area, others must also. Has anyone modified their chop saw to be more accurate or easier to use? I have looked around and all of the chops saws are about the same. It seems odd to me that they put so much into a miter saw but a chop saw is so basic.
WILD-BILL
Brook Park Oh
Only thing I ever saw was a friend who put a smaller chop saw blade on a miter saw.
And yes, I saw this after I had already bought my chop saw too.
bert.
australia
my old man has a block of wood thats cut at 45 degrees and it bolts to the back jaw with a wing nut so all you do is set the main back stop to 90 deg with a square and then bolt in the dit of wood when doing 45's if that makes sense. the only time i've ever needed anything other than 45 and 90 was when notching pipe
ElectroLight
Rockville, MD
No advice for improving a chop saw but when I was in the market I chose a band saw, cleaner cuts, much less noise and no fireworks to be concerned with. A cold saw would be even nicer but I can't justify the $$. I guess it all depends on what you need the saw to do.
bad_idea
Pasquotank, NC
I bought a Dewalt 12" compound sliding double bevel miter saw about 2 weeks ago. I thought of putting an abrasive wheel on it until I read the directions. The directions expressely said 'do not put an abrasive wheel on this saw'. For the money I paid for the miter saw, another $200 for a chop saw seemed like a good investment. :)
I like the idea of a chunk of wood cut at 45 degrees. I will have to look into that closer.
Any other ideas? Thanks all.
crewchief888
NW indiana
:beer:i dunno, but i'f you're looking for a perfect angle, a chop saw probably wasnt the best tool idea.
i use an adjustable angle finder/ protractor to set mine.
sberry
Brethren, Michigan
You rarely actually need a perfect angle especially for welded work. I rarely make a miter cut on a saw, I nip corners with a plasma or torch, rarely design anything that needs 45. You can notch with a chop saw,, its my go to tool for general maint type work, only occasionally use band saw.
I got a pic somewhere, we since modified the spark shoot to direct into the base properly.
cobymoby
Working with metal vs. wood are two very different things. Metal likes to bend and grab the blade whereas wood is a nice soft buttery material to work with.
DO NOT put a chop saw blade on a miter saw. That blade will shatter at a very high speed.
LSU
DO NOT put a chop saw blade on a miter saw. That blade will shatter at a very high speed.[/QUOTE said:
+1 on this. I saw the aftermath of a guy who did this. The chop saws have (or supposed to have) greater safety features in case the blade shatters.
The savings is not worth the risk.
darkk
Willimantic, Ct.
Thanks for making me spend money! I have an old left over 10" Craftsman miter saw and was thinking of putting a metal blade on it, I guess I won't now...
Mmfh
MEMBER EMERITUS
Portland Oregon
Did a little research on the subject of using chop saw blade on a miter saw, not a good idea and will void any warranty you have on your saw. The motors are wound differently and have a different torque ratio. You will eventually burn out the motor on your mitre saw if you do it.
I have the same Dewalt chop saw as the OP. Best thing you can do is use a really good cut off wheel on it. I used the one that came with it and it has too much flex to it. I picked up a thicker blade and its cuts much straighter and where I want it to cut.
Mm
larry4406
Northern Virginia
I had an old miter saw. I put a 10-inch abrasive disc in it to cut steel. i built 2 work benches and a rotissorie and the motor finally died. I agree that chop saws suffer with their poor miter function.
GirlnAgarage
Texas
If you guys intend to cut steel with a miter saw, use a saw in the proper rpm range for metal.
I have a Rage 3 and I love it. I've cut 1/4" thick mild steel. Let the saw do the work and use a good blade and you can make your cuts just fine.
bad_idea, I've seen a chop saw jigged up to make accurate repeatable cuts on steel. I'll dig up those links and get them to you. They might provide you with ideas you can use.
Mm
While not arguing about it being a good idea to put an abrasive blade on a saw designed for wood, I don't think speed is the issue?
My 12" chop saw is rated @4000 RPM
My 12" delta miter saw is rated @ 3500 RPM...
YMMV...
The guard IS a concern, the chop saw has a steel blade guard, the Miter is aluminum... (in some cases possibly plastic...)
I have doubts about the torque ratings being an issue; both wood and abrasive cutting are high torque apps, (Type of wood has a lot to do with the load placed on the saw, granted.) - Care to expand on what you found?
The Miter saw is not designed to eat the abrasive dust. The Chop saw is, as far as is practical. This is far more likely to smoke a Miter saw. (I have killed a couple of circular saws with masonry abrasive blades...)
rsanter
visalia ca
If you want greater precision you need to get a thicker piece of angle and make a new back fence, then dial it in very well and then drill some holes that you can drop pins in to index to the 90 & 45 as well as any other common angle you will be cutting
For thin tubing you need to slow how fast you push the blade through the material or the blade will wander
For thick material use a horizontal band saw
Bob
sfckiddo
use a T-Bevel to set the angle on the fence with the disc quick simple and easy
