mitakuuluu
- Joined
- Jan 29, 2008
- Messages
- 4
Great forum here, have been reading for a couple weeks getting ideas for an upcoming project... namely, finishing off my garage. Hope you guys and gals can help me with the biggest question of the project.
It's a 20'x20' garage, built in about 1970. Ceiling height (when installed) will be 8' - currently 12' pyramidal hipped roof.
I plan to put in R-30 or R-38 above the ceiling, and R-13 in the walls (2x4 framing). Will install several soffit vents to keep 'attic' at outside temp. Concrete slab floor, uninsulated as far as I know. Old wooden garage doors are 7x8, probably will be replaced with new R-8 or R-13 doors. One small window (36"x36") and one 30" door will be replaced with low-E vinyls.
I have electric service in there, but only two circuits of 110v @ 20amp. Looks like the original owner may have done the wiring himself; needs to be rerouted, maybe completely replaced.
I am debating whether to upgrade the service to the garage; if so, I'd put in a 100amp subpanel with 220v. Or, more precisely, I'd have an electrician do it.
So, the next question is heat. I'm in Western Oregon and temps rarely go under 25F in the winter, with usual highs in the 30s and 40s and lows in the, well, 30s and 40s. I want to be able to work in the garage in the winter at a reasonable temperature for doing painting and such. 65F would be my target.
As I see it, I have several options (we don't have gas on site, and I don't want to deal with propane):
1.) Keep existing electrical, try to heat with small baseboard heater or space heater.
2.) Keep existing electrical, get a 12,000 BTU mini-split system with heat pump.
3.) Upgrade electrical to 220v, get a big ol' electric space heater or baseboard heaters.
4.) Upgrade electrical to 220v, get a 18,000 BTU mini-split with heat pump and aux heat.
5.) Find a second-hand pellet stove and install it in the garage. This would most likely be against code, but we already have a pellet stove in the house and so fuel would be easy to find.
Thanks for any feedback!
