Best way to keep floor clean: snow, water, etc.
AverageJoe
Chelsea, MI
I've read the various pros and cons about Racedeck, VCT, epoxy, etc. Here in snowy Michigan one of the things that drives me crazy is the dirty snow and ice and leftover water all over the floor. I worry about epoxy and tile, etc. looking just as bad as bare concrete. The mesh type products probably let that stuff drip through so it at least looks good on top... but then what about all that gunk underneath? I don't have drains in my garage.
I don't prefer the cost of tiles, etc. But it does look nice. Is it a hassle to get it out of there? Do you have take it apart to do so? Does anyone have any tricks and tips for the snow, mud, water issue with tile and/or epoxy or similar floor?
nissan_crawler
Wichita, KS
rust-oleum epoxy for 5 years, no trouble. I put it down with light sand in it, still easily sweepable/easy to squeegee.
comp
Eville In.
somebody posted a link to a company that has drive on runners/trays that help catch alot
Jason B
PA
I just layed some cardboard down under where the stuff would fall. Has been working fine with my VCT. :)
A
AverageJoe
Chelsea, MI
Hey Comp, I'll look for the thread about the drive on runners/trays - that sounds interesting. (And, heard about the tornado in Evansville, assuming that's where you are - wierd weather it sounds like.) As for the cardboard, Jason, that seems like a good simple solution. However, alot of the gunk in winter comes off the tires or builds behind the tires on the car itself. Do you part cardboard down to deal with that stuff rather than under the body or engine itself?
Rte66Charlie
Ozark Mountains
What kind of floor do you have now? Are these questions in anticipation of a particular type of flooring, depending on the answers? Just curious, I have a garage floor on hold due to the (cold) weather and just wondering what your concerns are.
Epoxy should be a no brainer - nothing is going to get into it, sweep/wipe/wash, you are good to go. VCT? Does the adhesive squeeze up through the tiles enough to completely seal the floor? I don't know. Racedeck?? Lots of folks on here swear by it but I'm concerned about the seepage through the tiles and with the "open" tiles when you are washing it out, what about the **** that flows out under your "unopen" (for lack of a better term) tiles?
As far as ease of maintenance, I'm leaning toward epoxy (WolverineCoatings, expect a pm/email soon!) but I'd like anybody with other info to chime in!!!
RaceDeck1
Salt Lake City , Utah
On the issue of 'seepage' or what get under neath. Most garages in wet climates are pitched ( or at least have a drain ). The FreeFlow tile is designed to allow anything that goes through the top surface will flow freely through the understructure. In my garage, it just runs out the door, I can even wash my car all winter long in garage.
The best part is that you will not drag in mud and dirt to your house.
boiler7904
NW IN
I've got epoxy in my garage. My commute is an hour plus each way on the highway. The step tubes down each side of my truck pick up all kinds of salt, sand, cinders on the road in the winter. Whenever we get a warm day, I hose it out the heavy dirt to avoid scratches and then mop it with some Simple Green. Rinse and squeegee away any standing water. It takes about a half an hour to make the floor in my 2 car garage look like new. My garage isn't heated so I only do it if the temp will be at or above freezing for a few hours while it dries.
The most important thing to do regardless of the floor you choose is to brush of all the snow you can get to and then get the snow out of the wheel wells and off the running boards the best you can. Convincing your wife or girlfriend to do the same is a monumental task that I commend you on if you can actually be successful at it.
comp
Eville In.
yep thats where i am ,,thanks . We get them a lot :(
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Other than the hour commute, that is exactly what I do. SImple Green is the "cat's patoot". I just put some in a 5 gal. bucket, fill it up, slop it over the floor, take a broom and scrub it up, then rinse and squeegee. The Simple Green leaves a clean smell also. As far as the RaceDeck, etc, and not to knock a product as I would love to have it on my garage floor, but when dirty, gritty, snowy, salty water runs through and the water runs or drains out from underneath, you are still left with the crud. After one winter of dripping the crud through the tiles, there is no way that it does not have a ton of dirt underneath. After awhile, the dirt will cake and slow the seapage of water from draining. It happens on floor drains, it will happen under a tile. And when it does happen, you will start to get a musty smell. For water to evaporate, it needs air, if something is underneath a tile it will take quite a while longer to evaporate, and after the previous dirt gets damp, it will take longer and longer each time, until you have a very prolonged dry spell.
Kevin
