Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#21 |
Senior Member
#22 |
Senior Member
[QUOTE=
Stainless would be the best but again cost is a factor. The biggest issue is the system technique is 90% of the time pipe wrong ... the trunk line should be run pitched back to the compressor and the branches are to be teees faced UP and branch pipe taken off the tiop and dropped down the wall. Eliminates a lot of moisture problems. In any case standing water is a non issue so pipe corrosion would be eliminated if pipe propoerly. Ron[/QUOTE] Did I hear someone mention stainless? Here is my thoughts on over the top piping install. The air should be conditioned prior to entering the main line. When using the air for long periods of time it will start to build temps and start to collect moisture in the air stream. The moisture is not in large droplets but in a fine mist / atomized. So when using air, the mist (we'll say) will travel horizontal, vertical, or what ever direction the piping is set up. When the air is shut off it will cool and the mist will set up in larger droplets and simply lay in the low areas, thus the reason for traps. A over the top design is not bad but I feel it is not necessary. Sloping the pipe is a good rule to collect moisture in a controlled designated area. If the air is conditioned like I said than it should not matter at all if it is black pipe. |
#23 |
Senior Member
So the water can't be drained at the other end just as easy?
__________________
'06 Ford Mustang GT (weekend and track toy) '98 Chevy Z-24 (former DD and track rat) '07 Ford Fusion SE (wife's DD) '96 Mazda Miata M-Edition (current DD) '89 Honda Prelude Si "Magnum, PU" (24 Hours of Lemons Race Car) '89 Nissan Sentra "General Lei" (Rallycross Car) See my garage build thread here |
#24 |
Senior Member
''Galvanized IS a problem with natural gas though. For one, you don't have filters in natural gas, and for another, the odorant is known to slowly eat the zinc.''
We have installed strainers /filters in natural gas installation on the commercial installs. Most every natural gas emergency generator require a strainer too. Each manufacture and design engineer have different specs. |
#25 | |
Senior Member
Quote:
Use galvanized piping (SCH40), "black iron,"aluminum piping designed for compressed air (SimplAir or Infinity) or copper. |
#26 |
Senior Member
You can slope the pipe away from the compressor, http://www.tptools.com/StaticText/ai...ng-diagram.pdf. In my opinion(which may not be worth much) this is better then sloping back to the compressor, as long as you put a drain leg in the other end to drain the water. The air pressure is going to blow the condensation away from the compressor. Plus the air dries more the further away from the compressor it gets, they say 25-50 feet of pipe to allow the air to cool off and be able to get the condensation out of the air. I don't see how making the water that was forced to one end of the system by air pressure to drain all the way back to the compressor is better then putting a drain at the other end.
#27 |
Senior Member
The best way I found is to add a drip "tail" to every drop. My typical drop is 5' of 1/2" pipe, gate valve, a short piece to a T, 12~18" drop and another gate valve. I blow down the drops once in a while.
__________________
Chris - Merkel, TX http://raceabilene.com/kelly/hotrod GJ Build thread :http://www.garagejournal.com/forum/s...d.php?t=100482 |
#28 | |
Senior Member
Quote:
They use Galvanized Pipe for Dry Fire Sprinkler Pipe where air pressure is maintained until a fire ... I don't see any scaling obstructing 1/4" orifice in a sprinkler heads when there is a fire ? NFPA 13. They also use galvanized for Domestic Water piping ... large size grooved Victaulic ... scaling would clog your faucets ? Every Plumbing Code in the USA. The Code and All Specs recommend a drip leg on black pipe ? to catch scaling on black steel gas piping ... right . I would use the MAXAIR system in a Res Garage application before black pipe. Pitching the trunk back to the Compressor ... I guess the theory is the compressor runs for a short duration and shuts off ... so the water runs back to the compressor tank ... kind of takes care of the water automatically. I have a float style trap at the bottom of the tank which discharges condensate automatically. Float and thermostatic traps are mechanical units that operate on both density and temperature principles. The float valve operates on the density principle. A level connects the ball float to the valve and seat. Once condensate reaches a certain level in the trap, the float rises, opening the orifice and draining condensate. A water seal formed by the condensate prevents air loss. Ron Last edited by Ron Lombardo; 05-21-2012 at 08:23 PM. |
#29 |
Senior Member
I think the op trolled you guys into a "what oil is best" thread. Lol.
#30 |
Senior Member
''Whats the air different in NY ? LOL ''
It's not the air, it's the DESIGN ENGINEERING COMPANY that writes the specifications on what they want. It's their scope of work. Right or wrong, we do it. Everyone has their way of doing it.We've done Government jobs that said the same thing, no gal. It's not what we want but what they specify. Pipe is pipe, whatever pays the bills. |
#31 |
Senior Member
We use SCH80 galvanized pipe with SCH160 fittings (threaded and coupled) for 125-200 PSIG compressed air systems that are installed and operated offshore. There's nothing wrong with using galvanized pipe for compressed air. The oil company specifications usually allow SCH40 pipe for systems over 2.5" that are welded.
If galvanized pipe is good enough for Shell, Exxon and Chevron then it will be more than adequate for a home-owner. Last edited by stonesfan68; 05-22-2012 at 09:44 AM. |
#32 |
Senior Member
Even when the compressor shuts off isn't the lines still under pressure? How would water drain back to the tank if it's under pressure?
#33 |
I use black pipe in all 3 of my shops.water is the biggest problem I have 6'' drip legs with valves on the drops and i invested in a auto blowoff on the bottom of the compressors.The blowoff really helps the water issue.It blows about every 30mins for about 2 seconds.
#34 |
Senior Member
Stagnant air (Non moving air), even under pressure will act just the same as an open piece of pipe. Liquids will flow down hill also known as gravity.
#35 | |
Senior Member
Quote:
#36 |
Senior Member
For me, I just installed two high quality hose reels (one 1/2" for blast cabinet and one 3/8") that can service anywhare in the shop. No more fighting with coiled hoses on the floor and storing them. Eliminated the need for any type of air lines. That's how I roll... :-)
HAP
__________________
Who do I think you are? |
#37 |
Senior Member
BD1 as you can see there is a difference between what some engineer specs and what really works in the real world. Like what STONESFAN68 stated he uses in the most rigorous environment.
....and now your going to tell me you use teflon tape .... oh jes ...opened up another can of worms ... LOL |
#38 |
Senior Member
#39 |
Senior Member
#40 |
Senior Member
" ALL CLEAN ROOM PIPING STAINLESS and machine orbital tig welds . The price
of SS is off the charts.[/QUOTE] ... now your talking my language ... polished inside for FDA Approval and Certification ... we have used the orbital machines and boroscopes ... we use in Wyeth and Barr Labs. |
| Thread Tools | |
| Display Modes | |
