craftsman max axess
shoturtle
Frankfurt AM
Link-Belt
Arlington Texas
I picked up the smaller 19 PC. Set a few weeks ago at my local ACE hardware store for 33 and some change. Didn't really know of a need for it but could see the need to have it. Funny thing was as soon as I got home I found a good use for it on the neck fixture of my MC frame jig.
shoturtle
Frankfurt AM
I got the set today, overall it is not bad. The socket holding is sloppy as actually pretty loose, quality is not to bad, not as nice as the taiwan made ratchet. But the ratchet is very smooth. The set is not worth 100 dollars imho. But pass for around a 60 dollar purchase.
btbsandman
Missouri
I looked at that set in the store, and almost bought it. Then I remembered I have "Gearwrench" Ratcheting Combos at my house. I put the set back down and left it behind.
franzdom
NC
There are definite uses for these sockets that can't be handled by ratchet wrenches, my favorite use for them is strut top nuts which are down inside a strut mount, and you have to hold the strut inside it to keep it from spinning.
btbsandman
Missouri
I see some uses for these sets. Im a shadetree mechanic. I didnt have it ten years ago, and dont see how I need it now.
shoturtle
Frankfurt AM
I have to say, the ratchet is beefy compare to a ratchet wrench, so if you really need to crank down on a nut, it will take allot more then the ratchet wrench. The wrench getting into much tighter places.
But if you do get a set, they are 75 dollars online for craftsman club member and 10 off with june10. So it is 65 dollars if you have not points. Not a bad deal. The set gives me coverage on sae wrench sizes. On on the metric side it does cover form 3.5mm to 19, my ratchet wrench set only covers 7-19mm.
I did not know it till I got it, the torx and hex sockets fit standard ratchets as well. So it you do not have a torx or hex set for the ratchet. You have it covered with this set.
This set is worth 75 dollars, glad I got it for less. But I would not spend 100 on it.
This is my first chinese made craftsman item.
Mr Ratchet
I have the Kolbalt (Danaher) 1/4" and 3/8" sets with locking flex head ratchets. I'd put the Kolbalt ratchets a little above the CM MA ratchets. I also have a few adapters and longer extensions from gearwrench (Vortex). I just recently got a CM 3/8" MA to 1/4" MA and a 1/4" MA spinner handle.
The pass thru type sets are good as very low profile where a wrench may not have enough reach. They are also good for fasteners that may be counter sunk with a longer protruding shaft/threads.
I don see much of a point in the bit set. There are low profile bits or you could just cut one down if needed. They are nice in that they can be used in the pass thru style as easiely as a more traditional squared drive.
I just used my pass thru set the other day.
I could have hacked the threads down and used a standard deep wall. It was far faster and easier to slip on the pass thru socket and extension and tighten it down with the ratchet.
6-Speed
I bought a set and discovered the 3/8" drive 18mm socket would not seat all the way on the ratchet handle; turns out the socket had a small burr defect. I exchanged the set and made sure all the sockets seated properly before leaving the store. Aside from the poor quality control, this set has utility; it offers pass-thru 6-pt sockets that IMO are an improvement over 12-pt ratchet box-end wrenches.
shoturtle
Frankfurt AM
they made you exchange the whole set. They have them as individual sockets at the store. I am surprise they did not just exchange that 1 socket. The only socket they do not have at the stores yet are the hex and torx bit sockets.
rickhigginshtbr
Lower Bucks, PA
when I worked for Sears Hardware, it was the set I store used and kept in my desk so no one else could touch it. I wouldn't trust that ratchet on something you need to put a ton of torque on... broke the 3/8" one.
Chadwilliam1
Cincinnati
I have the gearwrench 1/4 and 3/8 drive set. my 3/8 drive has the locking flex ratchet. It is very nice, I don't use it very often but one thing I like is it is compatible with my gearwrench ratcheting tap handle.
Rezeppa
Newport, MI
I have the Matco special forces set and these sets are not needed. They are fancy ratchet wrenches with worst side tolerances. I bought it because I wanted a set of metric and standard in the basic sizes in one case. I have used it once. I would stay away unless it was a discount like stated earlier.
