locks for "vintage" tool boxes
posaune
Collinsville, Connecticut
What do you do for lost keys? I have a couple Huot rollers and a Remline without keys. The lack of security doesn't bother me, but the Huots don't close correctly without a working lock.
Should I take the originals somewhere to try to get keys for them or should I look for replacements?
It depends on the lock, Some are not easily replaced, others are a simple cylinder lock and are easily replaced at any decent hardware store.
Most use the standard "D" or double D (two flats, ) cylinder, and all you need do is match length, and re-use the hook/pawl from the old lock on the new one.
If it is not a match made in heaven, you can take the lock to a good locksmith and they can match the key pattern and cut a key from the number on the lock (expensive compared to a replacement Cylinder though).
lilredex
Toronto
When security is not an issue, like around a home shop, I prefer a thumb latch (or "dime" operated) style, where one is needed to keep doors closed, etc.
We can find both these at Princess Auto for a couple of $$, and they fit the common tool box configuration.
P
posaune
Wow- I think this would be perfect! I've never seen anything like it though - does anyone have a source in the US? If not, I'll just need to remember to pick up a few when I'm in Toronto in the fall (easier said than done...).
Harwinton
Look for somebody who collects old keys, and see if he's got one that fits. That's how I've gotten keys for the locks on my two toolboxes.
Souljer
Los Angeles, CA
Hi,
Long Answer:
I'm no expert at tools and toolboxes like you guys. I got lucky and the last old Snap-On tool chest I got (1980's vintage) came with a working key for the lock.
However decades ago, I found an old Yale padlock that I loved the look of. I have no idea how old it is except that it's at least 20 years old now... :lol_hitti
Needless to say, there was no key and no one knew what to do. I think I found it at a swap meet. Somehow an extra cylinder fired up in my brain and I took it to a local locksmith shop. They said if it's not a block of rust inside, no problem. I came back a few days later and this ancient beauty now has a working key.
I just got another vintage tool chest (I think from the late 1940s - early 1950s) that does not have a key as I recall. It's being shipped and now I don't remember. If I keep that one I'll remove the lock and take it to a Snap-On dealer or the local locksmith to have a key made. Then sell the 1980s one.
Short Answer:
- If you don't go with that "thumb latch", which does seem like a good idea:
• Remove the locks and take them to a local locksmith shop to see if they can make new keys for them.
• Maybe you could also simply replace the locks with new locks & keys that fit the socket?
lilredex
Toronto
Princess Auto has them in their "surplus" area, so when they are gone they are gone.
It is item #8430381....... $2 ea.
They came from (made in China),
Acar Industries Inc.
10325 State Rte. #43
Streetsboro, OH. 44241
800-732-7349
They could be outta biz.........web site no workee.
http://www.acar4hitches.com/
All is not lost, those latches appear to really be a luggage compartment latch on RV's. Amazon has them and lots here.....
http://www.ebay.com/sch/i.html?_trksid=p4069.m570.l1313&_nkw=7/8"+thumb+lock&_sacat=0
P
posaune
Souljer
Los Angeles, CA
Hi,
The latches seem like a great idea.
However -
If I can get keys for the original locks, I might do that too just in case I ever want to lock them (or sell them).
- that's my main motivation for getting keys made;
• it works as it was designed to and tools can be secured if needed.
• if I ever want to sell, it sounds good to say, "locks work and I have keys".
If you do try to get keys made, please let us know what did or didn't work and how difficult that was.
Brian_B_
North Central, AR
How about truck tool box latches? I got a set of them (keyed) pretty cheap at a local hardware store.
JASTECH
Gering, NE
Out this way snappy 2-sidded key blanks are $3.00 each + whatever they want to cut. So I will have my Dad (retired lock picker) order the blanks cheaper if he orders bulk. Then get the chart for lock code to key tumblers then he or I can cut brand new keys for snappy locks and not copying warn keys to new blanks. Anybody interested post here or maybe a new thread for the snappy key code for all to use.
PDF file for download if you could.
Souljer
Los Angeles, CA
Wow-
That looks great. Can't wait to get my box.
I dare it to not have a key! :)
However I was the one that brought up Snap-On. The original poster is talking about other manufacturers. Although the Snap-On locks may fit, who knows?
lilredex
Toronto
Here is a shot of other locks that could be used on tool boxes.
More secure locks, an Abloy and a P.O. box lock.
A slip ring adds security (from pipe wrenching) or can be used as a trim ring if desired.
No security needed here, just a thumb latch to keep the door closed
j.c.whitney
Omaha, Ne
If the lock has a straight cam or one with a simple bend, no problem. At least on a KR53 that cam would take some fabrication to duplicate. I bought my KR53 with no key and a locksmith made one in under 10 minutes. LDV and Snap On didn't have records for the lock used on my KR53.
thedrivingman
I picked up an old Proto (Kennedy made) machinest box with no key. I removed the lock and pulled out the pins. You can turn it with a screw driver to latch or unlatch the front cover. You could attach a finger lever.
