40x32 Nuclear Reactor
classic boost
canton, oh
moving into my childhood home and it has a few acres to build a garage. 40x32 pole building. scissor trusses (5/12 outside, 2/12 inside) to fit a 2-post lift.
here's the site before and after grading. it didn't look that sloped, but it took 24 tandem dump loads of fill!
edit- rehosted pics
https://scontent-b-ord.**.fbcdn.net/hphotos-xfa1/v/t1.0-9/197775_447409005269898_207028234_n.jpg?oh=e4c6b482ee9e985c410b8e0013fe20ae&oe=553C816B
https://scontent-b-ord.**.fbcdn.net/hphotos-xfa1/v/t1.0-9/269378_447953345215464_1819010879_n.jpg?oh=e02995550cac50a2f1d117ac9e0d485d&oe=5541CC1A
C
classic boost
canton, oh
it's getting late, so here's one before i hit the sack. the amish crew went from holes in the ground to this in about 6hrs.
http://sphotos.**.fbcdn.net/hphotos-snc6/s720x720/197775_447409005269898_207028234_n.jpg
C
classic boost
canton, oh
ok, i have time for one more. interior shot. 10' walls and 12.5' to the peak.
http://sphotos.**.fbcdn.net/hphotos-ash3/s720x720/550694_447413501936115_1344550641_n.jpg
ODIS
Nice build! At one point, for many years, contracted with a company in North Canton. Not Timken, and not Hoover (which I think subsequently sold out and went to China). The banking equipment company. Looking forward to seeing your garage space take shape.
Ody.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Another Buckeye!!! Welcome!!
The buildings looking good so far. You can't beat the Amish when it comes to putting these things up. What takes the normal individual three months the Amish have it whipped out in three days. Looking forward to seeing more pics.
BrianC636
Republic, Mo
Looks great! I like the idea of the scissor trusses! I think once I get my current 40x64 finished I have a great idea for my next one.
C
classic boost
canton, oh
siding was installed today. i don't have a concrete guy lined up yet. i dropped the ball on that, so it cost me time.
http://sphotos.**.fbcdn.net/hphotos-ash4/s720x720/250688_447953311882134_1106716703_n.jpg
http://sphotos.**.fbcdn.net/hphotos-snc6/s720x720/269378_447953345215464_1819010879_n.jpg
http://sphotos.**.fbcdn.net/hphotos-snc7/s720x720/307012_447954101882055_359093875_n.jpg
http://sphotos.**.fbcdn.net/hphotos-ash3/s720x720/551632_447954148548717_1128430383_n.jpg
BigGMC
Land of Confusion - NY
Looks great! Myself, I like having overhang on the gable ends.
Did you compare this post construction with regular frame on pad construction? I'm planning on the latter for my build (coincidentally a 32x40), but have been wondering what kind of savings a post build might yeild.
What size OHD's?
C
classic boost
canton, oh
doors are 12x8.
stick built was more, but after a ton of quotes, i can't recall the exact amount.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I really like the red siding with the beige trim. It's not a color that you normally see. Are you going to paint the door to match the trim or just leave it white? If it were me though, I think I'd paint it.
Before you concrete the floor, have you thought about putting a drain in? It looks that with the elevation, you could run a drain out the back over the hill. Again, if it were me, I think I would. That way, any winter snow or whatever could be squeegeed down. Just tossing out a couple of ideas. The garage looks great none-the-less.
C
classic boost
canton, oh
kevin,
yes, i'm going to paint the man-door. i'll wait till the big doors are hung, then color match.
there will be a trench drain in front of the garage. in the future, the driveway will be asphalted, then the water will be running towards the garage with quickness, so i want the water problem solved before it starts.
bdmach1
The garage looks amazing Paul.....I really like the color on the siding! Looking forward to watchin you start filling it up! :lol:
Bob
C
classic boost
canton, oh
fri- post holes dug
mon- post set, structure erected, sheeting on roof
tues- sheeting on sides, roof shingled
thurs- siding
basically, 3 days, as fri and thurs they were only there 1/2 day each.
edit- another way to look at it: they went from flat ground to finish in 24 working hrs.
NUTTSGT
Northern Central Ohio
there a 7am and all of their equipment loaded up and driving down the road before noon (and they even took a doughnut break).
crew of six for the building and four for the siding.
It's truly amazing the work ethic they have, it's been uncorrupted today's society and the modern work ethic. They have a work system down and holy cow does it work.
Wingnut65
Tampa Bay, FL
Wow. That is impressive. But that is the way they make money - put enough workers on it and hit it hard.
Nice build cb. :thumbup:
Nighttrain
Dripping Springs, Tx
They have to get back to tend to their crops. I visited several RV builders up there and most work from 4am to noon. This way they could get to the fields in the afternoon. Very nice build CB
C
classic boost
canton, oh
a few updates.
concrete is done. 4" over 2" foam board. a 12'x16' patio poured, too.
r15 doors installed
paint matched the man door
i have some pics of the pour, but they are on another camera that is mia at the moment.
http://sphotos-b.**.fbcdn.net/hphotos-snc6/s720x720/221812_476617902349008_1948218149_n.jpg
http://sphotos-a.**.fbcdn.net/hphotos-snc7/s720x720/319354_476617952349003_1282922065_n.jpg
http://sphotos-a.**.fbcdn.net/hphotos-snc7/s720x720/378187_476617999015665_1121574970_n.jpg
Milan
Westlake, Ohio
Nice space. I have been working on a 20x60 used scissor trusses also 10' walls atop 2 rows of block plus the truss...Nice ceiling height. gotta love scissor trusses. I used to work at LSI in North Canton. lots of nice realestate there. I also moved into my childhood home on 2 acres kind freaky!!!:willy_nil
