does the electric company charge extra to have a second service? i bet they do, ant that's why its "free". i think at our place, they charge something like $30 per month for the additional service, and the rates for that service are higher as well. doesn't take long for it to be cheaper to run it from your other.
Power company will charge $8.97/month minimum to have the service (so use $8.97 worth of power or pay that). This is in the South and is much different than up North which is what I am used to...
Real rough estimate, assuming a simple install of LC, Meter, and service drop mast.
8hrs labor
$4-500 materials
Right around $1000, but it can go up pretty quickly depending on hundreds of variables.
Why do you only have 30a available? would it be possible to upsize the feed? If so, you'd save yourself the monthly charge for a second meter.
I actually have a 100A breaker in my current panel that I could run to the shop, so that is another option depending upon what works out pricing wise. And the bonus of the 100A breaker to a sub panel is that I could do all of that myself...
The 30A is ran in a 3/4" conduit but unfortunately that won't be able to support the size wires to upgrade to 100A and it is all under concrete...
I would definitely look at running a bigger feeder line to the garage instead of a new service. Are you going to be running a business/shop out of your garage?
Renting a trencher and buying 100 amp stuff would be less than $600 in the area i live in.
Thanks. This is what I might end up doing depending on the quotes I get. I have 2 electricians coming out to quote it tonight and tomorrow. 100A would be "sufficient", 200A would be no worries at all about having problems. Between a dust collector, air compressor, heat pump and indoor unit, and running a tool, that is the potential to have 5 220V circuits running at once that I could see happening every once in a while. Add on top of that the 50A RV plug in that my parents want (I have a carport next to the shop) I could see using up that 100A service pretty quick.
I just had a 200 amp 8 breaker panel added to my small garage, new feed from pole, new meter socket w/ dual feed. (200amp to house & new 200amp to garage)
I purchased both panels, 200amp and meter socket, electrician provided AL feeder and conduit. (pole/transformer was right next to garage) I was the extra hand and it took us 1.5 days. This was a side job for him so did it in addition to his full time job.
Total price was $1400 to electrician.
Panels were: 200amp 8 slot Square D from Lowes $147, new Meter socket panel w/ generator transfer breakers $450-500.
FYI: small breaker count due to small garage and upgrading electric to install a hot tub next to garage.
Thanks you very much! I expect that my install will be pretty basic as well. 2x4 construction, brick wall exterior, nothing much that I can see causing any out of the normal issues.
Did that include running wires through out your shop? All I need is a panel hanging on the wall, I got it from there.
