Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 06-22-2012, 06:00 PM   #1
numbah9
Senior Member
Default Preparing for a concrete slab
So I've read a bunch of threads on concrete here and on other sites, but I'm still left with some questions. Could anyone please help me?
I have some very basic questions about re-doing the concrete on my garage floor. It was probably done in the 1950s/1960s, the garage measures approx. 20'x20'. The concrete looks pretty aggregate-heavy, and is starting to crack and crumble in some spots. It seems to have been poured as two separate pours, as opposed to one big pour with relief cuts.
Anyway, right now I'm just trying to run the numbers to see what it would cost to re-do the concrete. I would try and do all the prep myself (up to and perhaps including the forms), and then have someone come and pour it & finish it.
* Does my soil and water determine whether or not to use a vapor barrier, or are they always good practice?
* Does my plan to heat the garage determine whether or not to use rigid foam insulation underneath, or something else?
* Is 3"-4" of gravel/stone underneath sufficient for a typical pad pour?
* What determines whether or not my pad needs footers around the perimeter?
My ultimate plan is to epoxy the floor, so I think that means "yes" to a vapor barrier. But I don't know about the gravel/stone question, or even what kind of gravel/stone to use.
numbah9 is offline   Reply With Quote
Old 06-22-2012, 10:49 PM   #2
dcs Inc
Senior Member
Default Re: Preparing for a concrete slab
Always good practice, especially if the garage is a level area. If you can find some real vapor barrier material instead of the cheap visqueen, you would be better off. 15 mil is a good start.
If heating, for sure. If not even then it will help contain what heat you have in the space.
Yes. the biggest thing is to make sure it is compacted well. The best type of granular fill is crushed stone with a graduated size of 1.5" to fines. This compacts real well. Don't do the pea gravel, that invites moisture. Sand is tough to keep in place and moves around a lot when placing concrete making an uneven sub surface. gene
dcs Inc is offline   Reply With Quote
Old 06-23-2012, 05:41 PM   #3
numbah9
Senior Member
Quote:
Okay, great.
That's what I thought. Could you give me a rough idea of what I'd use -- the pink foam "boards", or something else?
So I compact the soil and the stone level too?
Also, I'm not sure if I'm going to epoxy the finished floor or not. If I do, then I'm going to want a broom finish on the pad, right? And if not, a smoother finish?
Old 06-23-2012, 06:19 PM   #4
dcs Inc
Senior Member
If a trowel machine is used, have them use their float finish blades and trowel as smooth as they can without "burning" the surface. this will leave you a smooth finish without glazing the surface. Final finish is determined on what you are going to do to the concrete. If you are not interested in an epoxy application, you may want them to burnish it tighter. (with trowel blades). if you want the surface open some, then the float blades.
The 2" standard rigid Styrofoam board is good to use.
__________________
Director of Training and Tech support: Gene Dean
Training Schedule
:http://www.elitecreteindiana.com
Email:info@elitecreteindiana.com
Tel:317-888-4440
Old 06-23-2012, 06:38 PM   #5
numbah9
Senior Member
The styrofoam goes on top of the compacted stone base, right?
Old 06-23-2012, 07:10 PM   #6
dcs Inc
Senior Member
You have to dig out the area so the top of the foam is level with the fill. This will ensure you have a consistant thickness of concrete.
Old 06-23-2012, 07:25 PM   #7
numbah9
Senior Member
Thanks. Given my climate, I'm going to need to pour like this right? Because the load of the structure is supported on the edge of the foundation.
Old 06-23-2012, 07:38 PM   #8
dcs Inc
Senior Member
Are you putting your insulation to the outside? Most all pours I've done, the rigid board is on the inside. I can't see any disavantage in this. Interesting.
We use this on masonary constructed slabs. Intalled on the inside of the block on the vertical plane and then lay the barrier flat toward the center of the slab, even with the bottom of the concrete.
Old 06-23-2012, 07:40 PM   #9
numbah9
Senior Member
I used that mainly to show the difference in thickness between the middle of the slab and that of the perimeter. I thought the insulation placement was strange, too!
I like to learn how to fish, instead of just buying fish.
Old 06-23-2012, 07:47 PM   #10
dcs Inc
Senior Member
Is this a monolithic pour? Meaning, footers-slab poured together?
__________________
Training Schedule
Tel:317-888-4440
Old 06-23-2012, 07:56 PM   #11
dcs Inc
Senior Member
If I'm seeing this correctly, the contractor will form the outside perimeter of the slab. Then apply the rigid foam to the inside of the form. I don't know how he is going to put the horizontal piece in or for that matter if it will do much good. If that's the case, have him form it 4" wider and double up the 2" of rigid board vertically. That will give you the best insulation.
__________________
Training Schedule
Tel:317-888-4440
Old 06-23-2012, 08:01 PM   #12
numbah9
Senior Member
Monolithic would be ideal, but I doubt that is possible. The structure has rotting sills, and has a slight lean, so it will need to be jacked up in order for me to fix the sills.
I imagine trying to bust up the old floor and re-pour the whole thing (slab and footers) monolithically while the building is jacked would be impractical.
The thread I started about the structure itself is here, but all the pictures are gone. I'm working on fixing those!
Old 06-23-2012, 08:57 PM   #13
dcs Inc
Senior Member
With the pics provided I'm kinda lost on how to help with what you say above. It's not that hard to figure out where to place the insulation. Just look at it this way. Try to get the rigid board as deep as possible on the vertical and 2 foot horizontal to the inside of the building. Set it at level with the subgrade.
Old 06-23-2012, 09:02 PM   #14
numbah9
Senior Member
Yeah, that makes sense. I think I was overcomplicating it!
Do you think the existing slab could be saved, or would it be easier to bust and replace?
Old 06-24-2012, 02:55 AM   #15
dcs Inc
Senior Member
Photos?
Old 06-24-2012, 09:10 AM   #16
numbah9
Senior Member
Gene, you can see them in this thread: http://www.garagejournal.com/forum/s...ad.php?t=91743
Let me know if you want me to take some more.
Old 06-24-2012, 09:37 AM   #17
nkachur
Senior Member
nkachur's Avatar
I am in Manitoba, With my slab (monolithic pour)the building designer / engineer specified 1.5" Polystyreen under the slab but not under the thickened edge, vapour barior on top of the whole base, 2" Polystyreen verticle around the whole slab and horisontal around the outside of the slab (as in your picture) to reduce the amount of frost working it's way under the slab.
__________________
Here is a link to my "I'm not sure what to call it build"
http://www.garagejournal.com/forum/s...ad.php?t=94224
nkachur is offline   Reply With Quote
Old 06-24-2012, 10:43 AM   #18
dcs Inc
Senior Member
The couple of pics of the concrete looks like it's shot. gene
Old 06-24-2012, 12:16 PM   #19
numbah9
Senior Member
Well, this is embarrassing, but it turns out the garage doesn't sit on the slab at all. It actually sits around it! It's like they put the building down, then poured the slab after. So the sills sit on soil (and a bit of rock here and there).
Does that change my best course of action?
Old 06-24-2012, 01:02 PM   #20
dcs Inc
Senior Member
Well, you need a footing system. You could jack it up to support the walls and hand dig a footer and pour that. In the Indy area an unattached garage requires 18" deep footer. That doesn't mean the concrete has to be 18" deep. The bottom of the footing does. Pour it up to allow for 1 or 2 courses of block. It's slow going for sure. I've done a few of these when I was younger. I've dug out and put basements under homes too. That was no fun either. gene
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
