Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 06-24-2012, 06:56 PM   #1
chris kenney
Junior Member
Default small westinghouse motor to drive joiner
I have an older Westinghouse AC motor 115volts/5 amps. The motor has 2 wires, one black and one red. I have a electrical plug I took off another worn out tool, plugged it in and connected the white wire to red and black to black. The motor started (shaft) turning immediatley, but black on black started to spark. I immediatley disconnected. The motor warns to make sure the motor in grounded. There is a green screw in conduit box (ground screw) I can't find? Any help how I can safely and hook this motor up to electrical source and ground motor?
chris kenney is offline   Reply With Quote
Old 06-25-2012, 09:17 AM   #2
pattenp
Senior Member
pattenp's Avatar
Default Re: small westinghouse motor to drive joiner
Can you post a picture of the motor connections and the information plate if there is one? Hard to help without actually seeing the motor.
pattenp is offline   Reply With Quote
Old 06-25-2012, 02:14 PM   #3
chris kenney
Junior Member
Thanks for reply. Headed to St louis. I will post tomorrow.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
