Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
Looks like sears is closing out on the cox reels.
http://www.sears.com/shc/s/p_10153_1...00100675&aff=Y On sale: $126.19 Reg: $299.00 Use SEARS5OFF50 or SEARS2012 for additional $5 OFF. Brian |
#2 | |
Location: PSL, FL Next door to Megan FOX, and down the street from Vanilla ICE
Quote:
#3 |
Senior Member
Not sure on the brand of hose used, but, the reel is top notch.
#4 |
Thanks for this!
I went for one. This will be good to have low on the wall and near the bench. And the EZ-Coil will be safer. BTW, If you order before midnight, you get an extra 5% off. Saved $11 total between that and the $5 off deal.
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4 my garage build | my wanted list |
#5 |
Senior Member
The 25' length kinda ruins it for me. You can't even reach around to a far back tire if you're parked right next to the reel.
I think for $15 more I'd go with this: http://www.sears.com/shc/s/p_10153_1...84000P?cw=true But that's just me...
__________________
I have 'diesel disease'. Actually, I not only have it, I am a carrier - I infect others. |
#6 | |
Quote:
__________________
#7 |
I bought one too...thanks for the heads up!
#8 |
Senior Member
I was thinking the 25 foot would work fine in my basement. If I like the reel, I can considering picking one up for my garage down the road. But yeah, 25 ft in the garage is a little limiting. I'd want 50 ft because I do string the hose outside the garage bay from time to time, but even if I was restricting use to the nearest bay I'd want 35 ft.
#9 | |
Senior Member
Quote:
I think im gonna spring for this, and mount it on the bottom shelf of my work bench, then I will have most of the 25ft to mess around with
__________________
www.olskool4x4.com This country, with its institutions, belongs to the people who inhabit it. Whenever they shall grow weary of the existing government, they can exercise their constitutional right of amending it or their revolutionary right to dismember it or overthrow it." -- Abraham Lincoln, 4 April 1861 |
#10 |
Senior Member
I bought one of these as well. I believe (but not certain) that these are also made in the USA. Thanks for the heads-up.
#11 | |
Senior Member
Quote:
Now, if you're getting it to mount to the ceiling of your shop so you can have an air hose handy for nail guns, air sanders, etc.....well, then that's a whole 'nother story. http://garagejournal.com/forum/images/smilies/spit.gif
__________________
#12 |
Got mine today. Yes, it's made in USA.
__________________
#13 |
Senior Member
Got mine yesterday too. Seemed like an open box reel, but nothing wrong with it, brand spanking new. Only issue is the cox reel box was just dropped into a larger box with no padding material. Well, the coxreel box itself has no padding either. So two layers of cardboard were insufficient to keep the center spindle nut from wearing through the bottom cardboard during it's trip. Every other order sears has shipped to me has been well-packed with packing peanuts (overpacked in fact), so I'm not sure what happened here. Nevertheless, it was annoying, but luckily for me no impact on the fuction of the reel. This thing is beefy and definitely overkill in my basement...but what's wrong with that!
#14 | |
Senior Member
Quote:
#15 |
Got mine a couple days ago and it had also worn through the box but luckily there was no damage.
#16 |
Notice the "This Side Up" on the Cox box? They put it laying down inside the Sears box. I have several Cox reels and they all have the same box and packaging or lack there of. If the shipper obeys the guidance on the box, everything should be fine. Mine was laid down as well but suffered no damage.
__________________
#17 |
Senior Member
I got my reel the other day. I had the same shipping issues as everyone else (brass fitting wore hole in box). Also, my reel has some issues with bubbling and peeling paint. I'm going to keep it though as it's going in the shop and doesn't have to look pristine. Good quality otherwise.
#18 |
Senior Member
Anyone replaced the hose on one of these? Used a longer hose?
__________________
Tools DON'T make the mechanic, they make the mechanics job, EASIER! |
#19 |
Senior Member
#20 |
Senior Member
Called cox reels. Gal there stated that the spring tension is designed for that specific hose. I asked about hose replacement and she recommended against it. I wanted a 1/2 hose though. After hearing that I ended up getting a 1/2 x 50' reel. Haven't mounted it yet but retrofitting and then having issues is not what I wanted.
Is you had a 25' and 50' reel parts list and compared parts then you could figure out if the majority of the reel is the same and maybe just change out the spring. Just a thought. |
| Thread Tools | |
| Display Modes | |
