Northern Tool 20" Oscillating Fan - Installed
machine_punk
Napa Valley, California
I don't usually re-post stuff from my main thread to other forums, but I thought the fan I just installed for cooling in The Aerodrome Studio might be of interest to folks who are looking for a relatively-inexpensive way to get some airflow in their 2-car garage...
It isn't a fan OF The Aerodrome Studio, it is a fan FOR The Aerodrome Studio!
While it is hardly 'hot' here in Napa Valley (I have lived in 130 degrees F (55 degrees C) in Iraq, it is warm enough to be sweating, while working in the studio. It isn't really hot enough to think about adding air conditioning, but I thought it was time for some air circulation in the garage.
You saw, a couple of posts ago, where I bought the 20" industrial, wall-mounted, oscillating, all-metal fan from Northern Tool. It seemed HUGE when I got it (I am used to the small, desktop oscillating fans).
Here are the details, for those who are interested:
Northern Tool. Q Standard Oscillating Wall-Mount Fan - 20in., Model# 10236, $109.99
http://www.northerntool.com/shop/too...7700_200467700
Unlike most guys, I actually sat and read through the instructions, before even touching the parts of the fan. One of the first things I figured out was that I would need to get some hardware for mounting it, since it was not included with the fan.
I worked through several ideas for mounting the fan, including lagging a 2x8 across a couple of studs and lagging the fan to that. The more I thought about it, though, the more I wanted to do something different. I already have two horizontal runners of STRUT along the wall, on which the Reconfigurable Tool Rack is mounted. I intentionally mounted strut all along that wall, for future expansion or reconfiguring the tool rack (hence the name). It occurred to me that I already have a mounting system available, so I shouldn't have to mount the fan on the wall.
No matter what I was going to do, I was going to need a trip to the hardware store. I have started stocking more standard hardware in the studio, but I didn't have some of the things I would need for this project. If I need 4 or 5 of some bolt or screw, I have started just buying a box of them. That gives me spares of stuff I've already used in my designs. For some nuts and bolts, I go to Blue Collar Supply, in Sacramento, California. They sell by the pound and are a LOT cheaper than even the box prices of the big box hardware stores. This is also where I get my sheet aluminum and some of my off-cuts of odd aluminum stuff...
http://www.bluecollar-supply.com/
Due to vehicle issues (the van is in the shop, and has been for a couple of weeks--the cooling problem ended up being a lot bigger than a simple water pump), I didn't have the option of heading straight out for the hardware store, so I worked on assembling the fan and a couple of other things first, taking up time until Mrs. Machine_Punk got home, and I could go to the hardware store.
Here, you see the original 'center cover piece' of the fan, which was a stylized version of the American flag (to take your mind off the fact it was built in China). While the center plate looked nice enough, you know my penchant for customization. I needed something which screamed, "The Aerodrome Studio." Hmmm...that gives me an idea...I cut out a circle of aluminum, installed a circle of purely decorative rivets, and stamped "The Aerodrome Studio" in the center of it...
View media item 22549
I still had a couple of hours before I had access to the car, so I started designing and building the plywood mounting plate. I finalized my plan and decided to use one (or two, if that wasn't sturdy enough) vertical strut pieces, attached to the already-mounted horizontal strut pieces, with a plywood mounting plate. I chose 3/4" plywood (19mm?), since that is what I had lying around the garage, left over from the Baileigh Bench.
I designed the plywood mounting plate with two options. Either one piece of strut, vertically, straight up the center of the mounting plate, or two pieces of strut, on the outside edges of the mounting plate. I suspected the single piece of strut would be more than enough, but I didn't want to build a new mounting plate, if a single piece of strut didn't work out. So, it is designed to work with either plan. Of course, it turned out that the single, vertical strut was more than sturdy enough...
View media item 22545
I went ahead and cut the strut in half (five feet (1.6meters)), instead of going shorter, so I would have more options in the future, whenever I move to another garage. I went ahead and fastened the mounting plate to the vertical strut, and the vertical strut to the horizontal struts, with the standard strut nuts (special nuts with springs attached to the back) (for more information on strut, go back about halfway in this thread...there are several posts on it). Just to the left of the vertical strut for the fan, you see the right side of the Reconfigurable Tool Rack...
View media item 22548
A couple more pics of the fan. The fan, oscillating to my right, allowing you to see the standard oscillating feature on the bottom of the fan. You can defeat this feature, buy detaching the oscillation arm, and reattaching it to the center of the oscillation knob (not sure if that made sense...but whether you attach it to the center or the outer rim of the knob determines whether it oscillates or not). If you defeat the oscillation feature, it will stay pointed in whatever direction you leave it...
View media item 22546
And a little further back, with the fan oscillated to the left. This gives you a little better idea of size, compared to a standard garage door rail. This thing is really pretty big. You can also see that the vertical strut piece continues almost all the way up to the ceiling. The fan puts out plenty of air in low. When you switch to medium or high, it sounds like an airplane, getting ready to take off...
View media item 22547
Overall, I am very pleased with this fan. For just over $100 (plus shipping), it seems to be well-built and large enough to blow air around a whole two-car garage. All of the components are metal.
Things I like so far:
- It is BIG and moves a lot of air.
- It oscillates.
- It has three speeds.
- I looks to be made completely of metal (steel fan shroud, aluminum blades, unknown metal motor cover, metal oscillating system, HEAVY steel mounting arm and bracket).
- It seems completely adequate for moving air in a two car garage.
- It mounts on the wall, out of your way.
- it is relatively cheap, at just over $100.
Things to consider:
- It is big, so you better plan ahead for a location and how you are going to mount it.
- It is relatively loud. This doesn't bother me, since I pretty much always have hearing protection on, while I am in the garage.
- The pull chain is short (but you can add a standard pull chain to it).
- The power cord is only about 4 feet long.
Working in The Aerodrome Studio is going to be a lot more comfortable during the warm months.
M_P
ScubaSteve
New Bern, NC
They have some decent prices on their air movers....I've been looking at getting one to build an air scrubber for the shop....keeps the sawdust down since I work with metal, wood, and paint all in the same place.
machine_punk
I saw something similar to that at NT this Saturday, but there was no price on them. But baby, they got fans. All shapes and sizes.
This one:
http://www.northerntool.com/shop/tools/product_200467702_200467702
#18923
Glad now there was no price, reviews ****. the one you have looks like a much better deal.
The fan in your link is the same brand, but doesn't oscillate (which may not matter to you...but was a key selling point for me). With the oscillation feature, mine does a good job of moving air for the whole 2-car garage.
M_P
