Flooring Options that will hold up to a forklift??
snowpromod
Northeast Ohio
Looking for some flooring options that will support light forklift travel? Is epoxy my only option?? Thanks
Sent from my DROID RAZR using Tapatalk 2
dandan111
Indiana
As much as I like to brag about rustoleum you better go with a industrial duty brand. I would go epoxy,just can't see using tile. Fist time you bang the forks on the floor those tiles will be broken.
thegarageguy
With all due respect, saying you need an industrial epoxy is like saying you need flour to bake a cake. What you need is the correct seamless system for your application.
First, you may want to consider polishing. This is a 12 to 15 step mechanical process, which includes chemical hardening, an optional stain and a high speed burnished final polish sealer. This can range from $3 to $8 per sqft, depending on size and site conditions
Another option is a shop floor (poured slurry system). This system consists of a penetrating epoxy primer, a poured and self leveled epoxy blended with aggegates to not only give you build but also more impact resistance, then top coated with a high traffic polyurethane or polyasapartic sealer. Typical cost is from $5 to $8, again, size and site conditions dictate final cost
Of course you can always opt for painting on a couple coats of "industrial epoxy" but it wouldn't last long in a fork lift environment.
Jack Olsen
Los Angeles
As a side note: I have never noticed any sound difference between dragging a jack across concrete or dragging it across tile.
dandan111
Indiana
I have drove forklifts in a few different places over the years and floors have been either polished concrete or epoxy. The best was a epoxy with the anti slip mixed in. If your only running a small forklift once in a blue moon that's one thing,if it's daily you better do as garage guy says. It's not going to be cheap to go industrial but sometimes is the only right way.
snowpromod
Northeast Ohio
Thanks for all the replies, here is a quick pic of my forklift. It gets used very lightly, pretty much to get seasonal items up/down from my lofts.
dandan111
Indiana
Snow pro that's a nice little tow motor you got. Looks like a once in a blue moon deal,I would go with rustoleum pro. I think the rustoleum will handle it and save some$$. As always the sky is the limit.
Garage Flooring
Grand Junction, CO
As the guy who used to do all the Forklift training at my old company, you should take that photo down :beer:
Two options:
Our Polyurea system (or a comparable system)
OUR PVC tiles, fully adhered
