Arrrrrghhhhh!!!!! It was supposed to be a quick job.
garboui
Southern Ontario
Today I leave work hoping to get 2 things done on the car before the sun sets. That was rear sway bar body mount bushings, endlink and both front endlins along with the belt tensioner assembly.
So get started on the rear end. first sway bar body mount bolt, comes out no problem. The second, SNAP! the head snaps off flush with the welded nut on the backside of the mount. The other two surprisingly not much grief.
Now the problem, my easy outs are at work (20min drive) screw it ill try the 'gra-bit' extrators. After some heating and such the screw extractors only manage to get about two turns out. Now go down to crappy_T and pick of another set of easy outs. Well that solution came to a grind real quick as i managed to snap the cheap fooking **** eating MasterCrap asstool easy out in the bolt real quick.
So now what? Im a little stumped as i cant drill at the extractor any and theres not enough clearance to get at the other side of the nut to try and twist the bolt through (i kinda wish i had a set of right hand easy outs).
Any suggestions on how I can go about fixing this? Pics below of the f-up.
Piper
Muskoka, Canada
One of the other things I think that helps this situation is the fact that the welding process causes a fair amount of heat to be created. The heat, by my way of thinking, also helps to break the rust seal as well. I've used this trick and just after welding the nut to the top of the broken part immediately cooled the whole area with cold water. This method of part removal works well but you just have to make sure you don't weld the broken part to the rest of the area..ask me how I know about THAT!
skyking
Dallas & Tulsa
I have done this many times myself. The heat helps loosen it .I also spray it immediatly after welding with wd-40 , the capillary action will **** the penetrant into the threads.
G
garboui
Southern Ontario
ok, now for another. After getting the rear buttoned back up the front links gave me some problems. The top nuts came off fine though the bottoms both rounded in the 5mm allen that holds the stud from turning. The allen key was even seated completely.
I have tried to drill them off though not enough clearance, even with a short bit. my only thought right now if to lop them off via angle grinder from the back sides of the mount. Unfortunately ill have to wait till tomorrow to make that much noise.
jetmech09
get a 90 degree drill. heat up your allen key a bit before using it. Use kroil. try an american size slightly bigger. get a bolt, stick head into allen key, use vise grips. or two nuts, or weld the bolt into the allen and use vise grips, or 2 nuts, or weld a nut. etc. etc. USE VALVE GRINDING COMPOUND ON YOUR ALLEN KEY.
G
garboui
Southern Ontario
Well, no amount of kroil would have gotten it off. I ended cutting off the endlink oin the backside then grinding off the flange till i could pry it out. Pic of the offender below.
When installing the new links it became apparent why any penetrant would have stood a chance. Honda ships the set of endlinks and the 4 nuts that hold them on. Not all 4 nuts are equal though, two are interference locking and the other two are normal. It still strikes me as something odd that they would only put the locking nut on the LCA connection and not the SB.
Professur
Mo-Ray-Al, K-bec, Ka-Na-Da
heat is always the right answer. If you're going to splash cold water on hot steel tho ... wear a face shield. If hot steam doesn't scare you, spalling shards of rust and metal should.
ra42mario
don't get to frustrated. Even in a professional setting with all the goodies we still have to hit the nuts with mapp gas torch (takes to long too roll out the torch cart) then put in the allen/torx key and turn the nut with a wrench. 75% of the time we end up having to grind them off anyways.
ra42mario
PB blaster just dissolves on a hot bolt/nut. I've never seen it "loosen" up a really stuck bolt in all my years. But then again, I live in the Great Lakes area. Our rust and the rest of the countries rust are two different things :)
G
garboui
Southern Ontario
I skipped straight to this route, I figured I had a 70% change of getting it off in a less destructive manner but i figured jumping straight to the angle grinder was some good time mitigation.
On the other hand, ive always contemplated picking up a set of nut-busters for times like these. Do these even work all that well?
http://www.princessauto.com/pal/product/2919587/Nut-Splitters/2-pc-Nut-Splitter-Set
CaseyJoes.
Strasburg, PA & Eastern Shore Maryland
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I agree with Zeke, use some ****** fluid instead of WD or PB. Besides that, PB Blaster smells too bad. If I use that in the garage, it will stink for days.
Dmaxman
Montreal, Canada
Links are pain in the ****. At the shop i just put a slice or two down each nut with the torch and then hit with the air hammer and they fall right off. Sometimes there is enough meat to grab between the mount and the link boot with vice grips to hold it from turning and since they are being changed you don't care about tearing the rubber.
purplezr2
Central MN
Not possible with endlinks since the studs need to be held with an allen key in tne center.
Some times if you hit it with a gun they come right off. No need to hold the center.
Another trick is to pound a pickle fork between the joint and the mount to create friction on the ball. Then hit it with the impact and they will come right apart.
ourkid2000
Nova Scotia
I live in the salt capital of the world.....they actually pre-salt the roads here in anticipation of snow. It's so messy.
Did my stab links a few months ago (6yr old car) and I actually didn't have any trouble. I sprayed them down with Kroil and let it sit for about 20 mins. Then after I got the car up and wheels off, before I did anything, I got my MAPP torch out and heated the be-jesus out of the nut. Then sprayed with Kroil again and started removing. It would start to back off and then seize up as it cooled. I just hit it again with heat and Kroil. The ol' Allen key was getting pretty hot even through my gloves!
Took about 3 applications of this technique and it all came apart no problem. Anti seize on everything with the re-install. Hopefully next time it won't be difficult.
Capt Chrysler
Middle of nowhere.
Had the same problem on the wifes Trailblazer a couple of weeks ago. Die grinder and a cut off wheel, cut the joint side off and tapped the rest out the hole. Son looks at me like what the hell are you doing? End of link problem.
Capt. Chrysler
