Rivets for toolbox restoration
BFBOB
This may be a yawner for most of you, but I'm excited! I've been enamored of Penncraft and Bernzomatic mechanics' tools since I bought them new to work on my first car in the early 70's. I went to a flea market today, one I go to fairly often. It's a commercial place with individual booths, so usually no garage sale prices, but now and then...
I spied the Penncraft toolbox, and was disappointed that it wasn't the kind with drawers, but the price was right at $1, even missing the tool tray. A few booths away I spotted a nearly identical box with tool tray and a few junk tools for $5. I snagged the tray, which fits perfectly, for $2. Then, to top it all off, rummaging in a tray of tiny wrenches marked 2/$1, hiding amongst the cheapie stamped ignition wrenches I found 4 small USA combos, including this Bernzomatic gem. There was also a Challenger-Proto long pattern 1/4".
I'd probably leave the toolbox as is, rust and all, except for the brown paint barfed all over the front. RustOleum makes a nice Hammered Finish paint that is an excellent match for the finish. I have some in Black that I used to paint a trailer hitch. It was a perfect match for the charcoal metallic bumper on my Escape. I'll have to see whether they make a dark gray; Black is too dark for the box.
What about rivets? If I repaint it, I'm going to remove the hardware and reinstall after painting. I don't want to use pop rivets or screws, but the only rivets I've found at the hardware store have a split shank, really intended for clinching on leather or wood. I'm sure I can make a peening tool to peen like the originals if I can find that type of rivet, with a hollow shank. Anyone have an idea where to look for them?
goodspeed
I used pop rivets on mine and attempted to hammer down the rough inside part. It doesn't look that great, but I didn't do a full blown restoration, so it works for me.
BFBOB
Oog. To me, pop rivets just scream "home made". Yeah, I use them, but pretty much only where they don't show or on things that ARE home made. If I can't get suitable rivets, I think button head Allen screws would look good, though obviously not original.
So, let's see... I'll need a $6 can of paint, 26 fasteners at, what, a quarter apiece? and a couple of sheets of sandpaper. Yeah, $14 to fix a $3 tool box. Sounds like The Garage Journal Way. :willy_nil:
BFBOB
Good grief. How could I not have thought of fleaBay???
Thanks, Dladcock - looks like these will work!
Brad54
McMaster Carr had some when I was looking several years ago.
They also have the "set" tool, that mushrooms the back side of it.
-Brad
Kevin54
MEMBER EMERITUS
Urbana, Ohio
The proper name for it is either Tubular Rivet or Drilled Rivet.
Don't go to Fleabay to buy them. Go to a Fastenal and save yourself a chunk of change, or post the size on here and someone would probably send you a few for postage. Myself, I don't know if I have any or not, but I can make the tools to seat the head and to roll over the other side. If you're only going to buck over a few, I can make the tool out of almost any type of steel. I don't have any tool steel because I'm just getting set up to get the machines going.
