Duck tape Bill
So I just moved into a new house back in July and we are finally getting settled in enough that I can start actually doing some of the projects I have on my list... one of which is to decrease the humidity in the basement.
The basement isn't "wet" by any stretch of the imagination; no water even after heavy rain, the sump pump almost never has to run except when the AC drips into it, but it's more humid down there then I would like it to be. I run a dehumidifier and that seems to do the trick, but I have plans to finish off parts of the basement and I want to make sure I seal up the walls/floor of the finished parts before I go hanging drywall ext.
My plan is to seal the floor with an epoxy coating, and that shouldn't be a problem... it's the walls that are problematic. They are already painted the the PO, and I'm not sure what they are painted with. It looks like white paint to me, but it could be drylok or some other water sealer, I have no idea. None of it is peeling or chipping anywhere and seems to be pretty well adhered to the wall (picking at it with a pocket knife does nothing to it). So my question is: what can you use to cover paint/drylok that is moisture resistant and doesn't require me to strip the old pain/drylok off the ~1600sqft of wall area like drylok says you need to do.
Any ideas would be greatly appreciated.
Edit: The walls are regular block walls FYI.
