getfamiliar
- Joined
- Dec 26, 2012
- Messages
- 22
Garage Gym in MN: Need Insulation Ideas!
I am in the process of setting up a small gym for myself in the smaller of our two garages. The garage is attached to the house as you can see below, but there are no heat vents leading to it.
Dimensions inside are 12' wide by 20' long. The height of the peak is 14', running down to 5' at the rear. I'll post a couple more pics shortly.
I'm in MN, and it's currently 11 degrees F. The question is - is it worth it to insulate the garage or should I just spring for a big propane heater (w/low O2 sensor) and run it as needed?
