A-symmetric or Symmetric 2 Post Lift .. I just cant Decide..
koster88
Hey guys.. I need a little advice.. I've read 100's of posts, watched tons of you tube Videos, talked to Shop owners, and Talked to Vendors.
I cant make up my mind.
I'll attach a pic of my shop layout. I *think* I want to put the lift sort of lined up up with my door towards the back of my shop. I have a Flat bed wrecked that i'd like to be able to bring inside sometimes, and the farther back I put the lift the better.
I will be doing General mechanics on anything from an old ******, to maybe something as big as an F250.
I would Prefer to be able to load a car in either direction because I have a lot room from the door to the lift, and not as much room from the back wall to the lift.
My Friends who own shops both recommend I get Asymmetric. But the lift guys I've talked to said just go "symmetric" and install them "wide" (145").
What do you suggest? Is the placement of where I want to put the lift an ok idea?
Thanks!!
bobj49f2
SE Wisconsin
I think you can only load a vehicle one direction with an asymmetrical lift. I have one and can only load it driving into with the front end. I like the asymmetrical because it's easier to open the door to get out.
The biggest concern is that you keep your mounting bolts 6-8" away from any cracks or expansion joints. The different manufacturers vary on the distance, I kept mine 8". Everything I did centered around keeping that distance.
K
koster88
How Wide are your Col's? I was told if I mount them at 145, I'll be able to easily open the Doors even if I go Symmetric.
Car Collector Chronicles
SE Wisconsin
I have an asymmetrical (Mohawk A-7) and do in fact load my 1997 Nissan Kingcab XE D21 Pickup in both directions, without any problem? Despite the high falutin' model name, it is a small pu truck.
volaredon
IL
partly depends on the deal you get; I got a symmetric; could not pass up the deal I got
have worked from both, don't matter to me
ringneck
Eastern Nebraska
I went asymmetric. You can load both ways, and depending on how long your door is, you may have zero chance of hitting loading it "backwards". I would definitely go for the wide option, as well.
gnxtc2
New york
Really depends on what you're lifting and in what direction you want it to face.
I went with a XPR10 and lift Ford diesel crew cab/ super cab both with 8' beds p/u trucks and cars. I'm not limited which way they face.
Billy T.
[email protected]
