Keeping my tools clean
FunkyfullWidth
Three Rivers, ma
Since I started wrenching i've always wiped my tools down after use. I've found that after a day of work, collecting all my things, cleaning them and putting them away makes me feel better the next day as opposed to walking into a shop with tools left all over the place or a big pile of dirty wrenches next to my box.
Thinking about it, i've noticed that I try to display the same respect for things that i'm working on. I like to take something apart, wipe the parts off and lay them out. Take parts out with as little force as possible, and then take a minute or two trying to understand how it works or what possibly went wrong.
When I first started spinnin wrenches I was a brute. I still have my moments.... But I've become more gentle with some of these things. Taking my time so I don't break an electrical connector that i've never seen before and most importantly using the right tool for the job. A wrench is not a hammer, a screw drivers not a chisel...
I don't know.... Thought i'd write this out because I feel that respect for things start with the basics and If you apply it to the rest of your life, it'll take you far.
dirtydogintex
inner looper-3rd Div Houston w & n
Congrats - have a cigar, you're gonna go far!
Isn't this all a part of 'growing up'.... maturing.... seeing the light turn on?
Some will tell ya, this attitude/enlightenment is one of the major differences
between a parts changer and a mechanic (or technician for all you whippersnappers)....
kursplat
S.Cal
i much prefer to clean up when i'm done for the day, and try to factor that time into how long i'm going to work on a project, if it's more than a day long. there have been time though the clock all of a sudden says midnight, and i realize, i'm waay too tired to spend 30 min cleaning up anything that doesn't need it :lol:
AL`
Texas
I prefer to keep tools clean to the extent of preventing rust and keeping the box and work area free of grime. I don't do it with the intent of maintaining a tool museum. A clean and organized shop is an efficient one and thus more pleasant to work out of. Of course, if you hit a chrome socket with wd40 and wipe it down, it looks polished afterwards. I like the patina and light scuffs of a well used tool over spiffy new but when I buy new I want them to be spiffy out of the box because I bought it new. I also like the way soft handles appear a little mottled from grease due to use, but I don't want my clean hands to get greasy when just picking it up from the tool box. I'll clean the grease off, but I won't endlessly scrub to remove it all if it has stained a little deeply. I guess I could have summed it up with reasonably clean and organized is good enough and the battle scars a well used tool picks up are badges of honor accrued towards their purpose for being around.
KPSquared
Wetaskiwin, Alberta, Canada
Here's where I fall apart. . .I can and do wipe down and clean up all my tools everytime I use them. . .but then, if I'm not thinking ill just drop the rag on the floor and walk away. Like my OCD short circuits. . . Weird.
woody 73
The Great State Up North
Funny because I have some of the ocd but I never clean my tools as a matter of fact the more oil,grease,lard, wax and gunk on my tools the better. Outside in the extreme weather of my garage exposed tools rust like crazy and all that gunk preserves them.
Sure they look like dog ****, but never any rust which is what I am trying so very hard to stop in the first place. My hat is off to the op for wanting to keep his tools looking very nice.:rocker:
rick carpenter
Huntsville, East Texas
I take mine to the grinder and "buff" the hell out of them after I use them. For hours. Some days, I just buff them for no reason. Gotta get me some new ratchets though, my 3/8 is now 1/4...
supra90turbo
Central MA
holy **** that's me right there. I just had a good laugh!
otis66
Cleaning your tools at the end of each day also helps you keep track of all your tools....No more lost tools.
fringeofinsanity
Elgin, IL
I tend to wipe my tools down even throughout use, unless I'm doing a longer, greasy job like pulling a motor. Then they get wiped down during a small break or at the end of the day as I put them away. Very rarely do they not get put away at the end of a day, even knowing I'll be grabbing hat same wrench first thing in he morning.
It used to drive me nuts when I worked in a shop and would be working with someone that never cleaned his tools. I must have control issues over and above my OCD. LOL
richfinn
Leeds, Yorkshire, England
I keep my clean tools in my Toolbox, and the dirty tools I,m using on a simple 2 shelf cart. When I finish a task the tools on the cart get wiped off and put away for the next job before the car leaves the workshop. Its not OCD, its common sense to know where your tools are and not be covered in oil and grease.
Same goes for the workbench and floor, I have seen people have a workbench piled so high with **** its useless and be wading around in coolant/brake fluid/gearbox oil swearing under their breath that they are getting all the **** jobs and not earning as much as the other mechanics.
Zeke
Now that right there is funny.
I can't put a dirty tool away, but it doesn't have to be anything but simply clean. Little brake parts spray and in they box they go. You never know, the next job might be a clean job, like around upholstery.
ryan t
Bristol, Va.
This is me. I"m fine getting greasy but if I just need to grab a tool for a quick job that doesn't require getting really dirty/etc I"d rather not have to grab a nasty greasy wrench.
mailpup
Los Angeles
Like most people I will clean my tools thoroughly after each job is finished. I'll also dress chisels or similar tools that may have gotten nicked up. There are times when I will delay the cleanup until the next day such as when I finish the job at 2:00 a.m. or something. After all, sometimes it will take another 1/2 hour or so just to clean me up. In any case, the tools don't go back into the toolbox unless they are wiped off or cleaned.
I sometimes clean tools during the job when they get unusually grimy, particularly if I don't want to transfer the grime to a clean fastener. Just like I clean my hands periodically during a job.
Chris_PT
Shreveport, Louisiana
I clean mine generally after every use or the completion of every job. I am just a hobbyist/side-work kind of guy, so it's nothing but my time. I will admit that I am self-diagnosed with OCD (lol), but if you saw my tools or anything of mine, you would agree
Rico.
England
I use Unicorn horn oil and Egyption cotton Q tips... Really does the trick.
jvitez
Big Sky Country, Canada
Wow: doing it right, doing it carefully with respect, keeping things clean, and thinking about what you're doing. You're hired. Well done!
Two truths:
1. Change your behavior and your thinking changes.
2. You become what you think about.
Keep it up!.
greasemonkey44
memphis
i usually just wipe them down
if they are really funky i run them through the partswasher
ive done that since day 1 though
now i know when to take a break and leave a problem alone for a while so i can think it over......that took some getting used to
Larwyn
Texas
For a few years I was the front end and brake mechanic at a tire store that furnished all my tools. I soon learned to wipe the tools down to get rid of the grit and grime before coating them with a nice clean layer of wheel bearing grease. This served to keep them in the box near the alignment pit where I needed them. Many times I would walk straight from the tool truck with a newly acquired tool, smear it with grease and put it away. I only started this after finding a much needed fixture for bending twin I-beam axles being used as a wheel chock in one of the bays.
These days, I am retired, I am the only one working in my garage and my tools are clean even if they may suffer a bit more from exposure due to the lack of grease. Dust and corrosion are a much bigger problem with clean tools.
purplezr2
Central MN
Never had rust issue, and my tools live in 90+ to -30. I say that is a piss poor excuse to not clean tools
Part of the reason I clean my tools as I put them away, allows me to check to make sure everything is there.
davesnothere
phoenix, az
I like to keep my stuff clean too. Im not **** about it, but it only takes a second to wrap a rag around something before it goes back to its home.
ADSR
Once every two months i have my detailer come in and wax my box and detail all the tools.
ryan t
Bristol, Va.
I use Spartan SD-20 to clean my hand tools, workbench, shop stool, non-moving vise parts, etc. Anything that doesn't require lube it will clean and it won't harm paint/finishes. Let it foam for a few seconds and wipe it off, great stuff. Sticker residue, gone. Grease, gone. Love it.
F
FunkyfullWidth
Three Rivers, ma
Re: Congrats - have a cigar, you're gonna go far!
Ya see, I used to always use brake cleaner but over the years found that some tools don't have part numbers or names stamped in, but rather just written on. The brake cleaner usually takes that off. Every once in a while I'll clean ratchets and adjustables in diesel and then wipe it all down with some wd-40 on a rag.
If i'm at a certain point in a job i like to pick everything up, wheel the cart to my box and put away everything i don't think i'll need.
This post right now is stemming from seeing how other people work. Everythings a mess, they look like they just got out of war. I mean everything smeared with grease, air line, extension chord, door knobs... I don't know how these guys take a leak.... reminds me of the thread on pirate, "help i got herculiner on my hootus."
And that's the thing... Alot of people don't know how to keep a neat shop. I think a neat shop can be a difficult thing to accomplish. For instance, where I work it's a 60 x 80 shop. That's a lot of floor space to collect...."items"... Over the last 2 years i've been trying to find a way to organize small engine parts, heavy equiptment parts, pickup truck, and class 8 truck parts. All it takes is one guy that doesn't really give a **** to come in and leave a jug of washer fluid here, or an extension chord out.... **** piles up fast.
nanofrog
I prefer to keep my stuff clean, and it looks a lot more professional (carried into offices).
It also means I have to be very diligent in accounting for them to be sure I have them at the ready. That, and it's rather expensive to keep replacing stuff I was too dumb to keep better track of.
Heavy Metal Doctor
Mason Dixon Line
Just had this conversation with the boss. I told him how I will be rearranging some shop supplies / specific task space to make better use / flow of work. The subject of a needed spot for a vice and a mount for the hyd. hose crimper came up and he insisted we should just move another existing table into that area. I said "no - we don't need table space for that work - it would just end up like the other table" and pointed to the one littered with extraneous **** that everyone leaves on it....him being one of the worst offenders....
I fight the mess constantly. My helper is like working with Pigpen from the Peanuts - hoses, cords, old parts, drain pans- you name it - all mixed with hand tools for the current job (half of which he has to borrow from me). The mess will always build up during a job, but I'm talking about mess from previous jobs. He WILL clean up, but only when specifically ordered to do so....
I try to always work off a cart and wipe everything down / put it away at the end of the job. Partly to be clean / neat, and partly for inventory sake - I hate having to buy tools to replace lost ones. When workload allows, I do and extra hour or 2 of general cleanup - extra stuff like wiping down the whole outside of the tool box - once a week or so.
F
FunkyfullWidth
Three Rivers, ma
Heavy this is where i've been. I spent two days a few weeks ago picking up the shop... I moved everything and washed/scrubbed the floors then squeegeed them. 3 days later, it already looked worse. All thanks to a guy that doesn't even work there. It's been turned into a body shop. He pressure washes inside, and has been painting trucks and **** inside.... Drive me insanse. Right now there's a pile of trash 6 feet tall all from him. At this point all I can do is keep my **** clean for the most peace of mind as possible...
At the end of every job big or small, and sometimes in the middle I like to collect all my hand tools to wipe down and put in my box leaving out only what's needed. i hate seeing chords left on the ground from days ago, or the air hose still on the ground... The drop light left on. **** drives me insane...
Heavy Metal Doctor
Mason Dixon Line
Me too. The best part of air hoses laying around in our shop is the fact that we installed slow rewind reels all over the shop -- everyone seems to know how pull them out, but not reel 'em back in.....all it takes it a tug and let it go.....
zmotorsports
Northern Utah
Well said. I think I do this with all aspects of my life. My shop, tools, home, vehicles, they all have to be clean and well maintained or it drives me crazy. I take pride in not only my work but in my assets and those things that I am a steward of. I also apply the same principles to every vehicle, motorcycle, ATV of others that enters my shop.
I think it is called OCD.
That is what the wife tells me.
Same here. If I knick a chisel or drill bit, it gets dressed right away. The tool doesn't get put back into the toolbox unless it is in "ready to use" condition and awaiting its' next task. I too clean tools if they get especially messy during a task, such as a ratchet/socket getting oil soaked as I drop a transmission pan will get cleaned/wiped down before I even set it on the toolcart. It then gets thoroughly cleaned prior to going back into the toolbox.
One would have OCD if he had two stages of rags for cleaning - one pass with a regular rag and a second pass with a clean rag.
Then I guess I would fall under that criteria. I have different stages of rags/paper towels. Clean ones that are in my pocket for cleaning things that are already fairly clean, somewhat dirty ones that still can retain grease/oil and not get your hands dirty by using and they they progress to the stage of being one step before the garbage. Those are used for wiping up a spill or drip on the floor and then into the garbage can.
All tools are generally cleaned with a somewhat clean rag while working. It is actually more of an unconscious reaction now to just wipe a tool off before I set it down even if just setting it down on the workbench or tool cart.
ALL tools are thoroughly wiped down with a clean rag prior to being placed into its' home in the toolbox. If they are greasy such as the new Snap-On grip handles on the screwdrivers or pliers which seem to retail some grime, then I give a shot of brake wash onto the towel and wipe the tool off prior to putting in the toolbox.
I am the same way with components of vehicles/motorcycles. As the vehicle is coming apart I decide which parts need light cleaning and which ones need heavy cleaning and set them aside accordingly. Again this is more of a habit or reaction now that consciously thinking about it. Those parts are cleaned by either the solvent tank if really bad or a quick wipe with a semi-clean towel and some brake wash or Power House cleaner so when I get the parts I can simply put things back together and everything is clean awaiting assembly.
It generally goes much quicker than it sounds and actually I can work much faster with a clean shop, clean tools and clean parts than when things are filthy.
Mike.
RCStocker
Indiana, California, Australia
If you want clean tools you will never use them. LOL
Just wipe them down after every job and put them back in the box. You might do that 10 times a day. You never loose tools and they are always clean. If you take time to be neat and clean you will not be looing for things or wondering where they went. It applies to everthing else in life as well. Good habbits makes life easy.
